Transmission Overdrive Problem
Old 03-02-2011, 03:11 PM
schamsy's Avatar
schamsy
schamsy is offline
Hey Guys,
I am having some sort of transmission issue. I was driving my truck, in overdrive, and I downshifted into 2nd gear when going down a hill to engine break. I was going about 45 mph. When I go to the bottom of the hill I hit the gas and the rpm gauge just went up, no power to rear wheels. I pulled over shut the truck off and started back on my way. I accelerated through first gear and second gear, and once it was going to shift into third the rpm gauge just shot up again and no power to rear wheels. Again I pulled the truck over and shut it off, started it up and turn overdrive off. This time I had absolutely no problems, it runs perfectly fine. There are no codes being thown or any signs of a problem. I have been very careful to make sure I push the overdrive off button each time I start the vehicle up to make sure I dont hurt anything more than I already have. Does anyone know what I could be experiencing here?
Truck info:
2004 F-150
2WD
4.6L
Extended cab
70,000 miles
Thanks,
Nick
Old 03-02-2011, 06:17 PM
shorebird's Avatar
shorebird
shorebird is offline
First off; Welcome to FTE.
Second; brake pads are cheaper than transmissions.
You need to have the codes read at a local parts house.
Old 03-02-2011, 06:22 PM
schamsy's Avatar
schamsy
schamsy is offline
I'm so confused by what you just said.... what does this issue have to do with my transmission... there are no codes I already checked.
Old 03-02-2011, 06:55 PM
1bad67sbf's Avatar
1bad67sbf
1bad67sbf is offline
he said use your brakes not 2nd gear and find someone with a GOOD scan tool like snap on and have them check it over, alot of the time they can see an issue that autozone style scanners cant see
Old 03-02-2011, 06:56 PM
1bad67sbf's Avatar
1bad67sbf
and he said welcome to the forum
Old 03-02-2011, 06:57 PM
schamsy's Avatar
schamsy
schamsy is offline
Ok sorry I wasn't thinkin like that. I definetely wont be engine breaking anymore.... does anyone else have any input?
Old 03-02-2011, 10:51 PM
sandrat's Avatar
sandrat
sandrat is offline
No third or fourth? Sounds like the direct clutch, but if it's working fine now, could be a solenoid or valve body issue. Definetly take it somewhere professional and have codes pulled, preferably a trans shop who know how to inspect the transmission controls (solenoids and valves) to determine what's at fault.
Old 05-03-2011, 09:47 AM
AFReserve's Avatar
AFReserve
AFReserve is offline
Hard overdrive shift
I have a 2007 f150 XL 4.6L and roughly 62k miles on it and just recently started this issue. When i get to cruising above 40 mph approx. when it gets into overdrive, when i give a little gas to say speed up a little bit or go up a hill or what have you, it hits going down back into the lower gear and then hits a little less hard going back into overdrive. Any ideas about what this might be? All other shifting does smooth as always, just coming in and out of overdrive gear.
Old 05-03-2011, 10:22 AM
bigunit54's Avatar
bigunit54
bigunit54 is offline
Originally Posted by schamsy
Hey Guys,
Truck info:
2004 F-150
2WD
4.6L
Extended cab
70,000 miles
Thanks,
Nick
I know exactly what you have because I had it. I am no tranny expert, but it has been described to me as a little clip that holds the overdrive servo together and sometimes it has the tendency to break. I was same as you. I lost 4th gear, but had 1st, 2nd, 3rd. My truck was Ford certified so I got it fixed with only the 100 dollar deductable. Here is a thread about it.
https://www.ford-trucks.com/forums/9...ml#post9206889
here's another:
https://www.ford-trucks.com/forums/1...overdrive.html
and another:
https://www.ford-trucks.com/forums/1...ml#post9580540
The first thread probably describes the problem best. The 6th guy to post on that is a tranny mechanic, so he explains it a lot better than I can. Good luck, let us know.
Old 04-04-2013, 02:35 PM
jwh9652's Avatar
jwh9652
jwh9652 is offline
I am having problem with my trans shifting when load increases gradually. Does not seem to be as bad if the overdrive is off but still happens. Any ideas f150 2007
Old 04-04-2013, 07:43 PM
ojai150's Avatar
ojai150
ojai150 is offline
I had the same little snap ring break on my '04 at 90,000 miles.
This is an " in truck" repair. Go to youtube F150 transmission repair part 1, 2, & 3 shows exactly how to do it, very simple fix.
Even gives snap ring part number
Transam461
09-10-2016 12:58 PM
Sean Orr
1997-2006 Expedition & Navigator
06-28-2016 02:06 PM
Ad01011
01-18-2016 01:39 AM
HMS
1999 to 2016 Super Duty
03-02-2014 02:41 AM
Kookadala
50
11-03-2013 09:26 PM
Quick Reply: Transmission Overdrive Problem
