1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Is it haunted???
Old 03-02-2011, 11:06 AM
ab123's Avatar
ab123
ab123 is offline
Is it haunted???
I am new to this site, and it's great. I have a 2003 Expy. that has some wierd issues, you will be driving along everything fine then the interior lights come on,the door ajar light comes on and the annoying ding ding. all doors are firmly shut. It will even do this while parked in the drive-way with no one around it. My kids think it's haunted, do I call the Ghost Busters or can someone here help. I have tried to squirt WD-40 into the doors to wash stiff grease on switch pins, but no help.
Old 03-02-2011, 11:59 AM
alloro's Avatar
alloro
alloro is offline
Received 4,174 Likes on 2,419 Posts
Did you also WD-40 the switches for the rear glass and hatch?
Old 03-02-2011, 12:11 PM
ab123's Avatar
ab123
ab123 is offline
Tried but don't know if it's getting to where it needs to be.
Old 03-02-2011, 03:06 PM
ab123's Avatar
ab123
ab123 is offline
Anyone fix this? I think it is the drivers door, but can't be certain. Would it really be caused by old hard grease like I have heard? Why would it just do it at random times?
Old 03-03-2011, 06:00 AM
broncoholic's Avatar
broncoholic
broncoholic is offline
Since you've already tried the WD-40 in the switch areas, I vote for haunted.
Old 03-03-2011, 07:49 AM
RedHorse1's Avatar
RedHorse1
RedHorse1 is offline
switch could be damaged rather than gummed up
Old 03-03-2011, 07:57 AM
fordno1's Avatar
fordno1
fordno1 is offline
Good chance a door ajar switch is bad. Which one? Start with the drivers or passenger front door since they get used the most. Take door panel off and get to the switch and clean it, test it. You may need to replace it. This might be a trial and error thing. Not sure if there is a way to figure out with a scan tool what door it is coming from. The switches are inside so spraying WD-40 is probably not going to help. If the switch is bad, that won't solve anything. Oh, you may want to use something different like a white lithium grease for lubricating the door latches. WD-40 is messy and doesn't lubricate well, it drips off and soon it will be dry and you will have to spray it again.
Old 03-03-2011, 10:53 AM
alloro's Avatar
alloro
alloro is offline
In that case you might just have to remove the door panels so you can get in there better.
kind153
05-25-2014 06:19 PM
Yougotthehit
1999 to 2016 Super Duty
03-07-2009 05:25 PM
theangryviking
08-31-2008 11:31 PM
RDC F250 7.3
34
12-07-2007 10:25 AM
Hoosierdaddy
18
06-27-2005 03:44 PM
Quick Reply: Is it haunted???
