Can I set my door lock to match my ignition key? - Ford Truck Enthusiasts Forums
Old 03-02-2011, 10:37 AM
nairod nairod is offline
nairod is starting off with a positive reputation.
I have a 76 F150. Got it without keys, so years ago I had a locksmith cut a key to fit my ignition, only. I've never been able to lock the doors. Well, I'm tired of no radio/CD but before I put something in I want to have a working door lock.
Can I pull the door lock cylinder and change the innards to match my ignition key? Are there a different number of pins that makes this not possible?
I've seen some stuff on utube but I figure this is the place to find out the real deal.
Thanks!
Old 03-02-2011, 11:45 AM
jim collins jim collins is offline
jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.jim collins has a good reputation on FTE.
A lock smith can and you probably can if you had an assortment of pins. I was lucky to find my old 79 i was getting parts off of for my fixer upper one had a good ignition and door locks that did just use one key. The problem i think is having the pins. Being a carpenter i have done a lot of house door locks that way and they are built allmost like our truck locks.
Old 03-02-2011, 11:46 AM
wezol5484's Avatar
wezol5484 wezol5484 is offline
wezol5484 is a splendid one to beholdwezol5484 is a splendid one to beholdwezol5484 is a splendid one to beholdwezol5484 is a splendid one to beholdwezol5484 is a splendid one to beholdwezol5484 is a splendid one to behold
You can also scribe one side of the key for ignition and the other side for doors. That's the way mine are. Unlock the doors, turn the key over and start the truck.
Old 03-02-2011, 01:19 PM
Nazty 4X4 Nazty 4X4 is offline
Nazty 4X4 is starting off with a positive reputation.
a local lock smith could help ya out.
Old 03-02-2011, 01:22 PM
I pulled apart one door cylinder. Using my ignition key, it looks like I can reposition 4 of the 5 pin sets and have it work. I'm planning on just leaving out the one set of pins that's too long.
I'm soaking everything in mineral spirits right now. I should know if I've got it in 1/2 hr or so.
Old 03-02-2011, 01:46 PM
Ronzi's Avatar
Ronzi Ronzi is offline
Ronzi is starting off with a positive reputation.
You can buy new locks on ebay for like 70 bucks. It will have 2 door locks and an ignition lock and 2 keys.
Here is a link to some......
NOS 1979 FORD TRUCK IGN. & DOOR LOCK SET 79 F100-500 - eBay (item 370429695544 end time Mar-06-11 13:16:57 PST)
Old 03-02-2011, 02:21 PM
zenmaster's Avatar
zenmaster zenmaster is offline
zenmaster is starting off with a positive reputation.
nairod,
Take the 5 pins from your ignition down to your local Home Depot. Go to where they cut keys in the hardware dept. Show the associate the pins. HD carries pins for rekeying Schlage and Weiser locks. Measure the length and width of the pins you have and try to match them up. I bet HD won't even charge you for them.
Cheers,
John
Old 03-02-2011, 04:15 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
With the key in the lock , if you have the pins exposed , use a file to shorten the ones that are too long ...
Old 03-02-2011, 09:55 PM
Well, I lucked out. I moved the pins around until I had 4 of them flush with the inner cylinder's outer surface. I left one out. Put it all back together and it works great.
If you look really close, you can see I did slightly mar the outer trim piece when I removed it. A few scratches... heck, doing it myself and having a working door lock sure outweighs those blemishes.
Rick, that's a great suggestion, by the way.
Old 03-02-2011, 10:40 PM
Yep , I have done it many times ...
Keys, Locks, & Ignitions Moe Craig 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 01-07-2016 10:14 PM
Match new Ignition to old door locks Diesel_Brad 1987 - 1996 F150 & Larger F-Series Trucks 22 12-12-2015 11:33 AM
1952 Ignition Switch BlueOvalRage 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 11-10-2011 04:56 PM
Lock & Key question 5 star cabs glovebox etc jmadsen 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 09-22-2011 12:34 AM
Ignition/Door Lock 69 F-100 Cracker289 1967 - 1972 F-100 & Larger F-Series Trucks 5 07-20-2011 04:43 AM
Tags
1964, 1980, 79, bed, door, f150, falcon, ford, ignition, keys, lock, locks, match, matched, matching, set, trim, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
