DASH PAD - Ford Truck Enthusiasts Forums
DASH PAD
Old 03-02-2011, 10:02 AM
RANGER589 RANGER589 is offline
RANGER589 is starting off with a positive reputation.
DASH PAD
The dash pad on my truck was painted tan. It is starting to peel. The original color is black and I would like to strip it to the original molded color.Anybody know what would be a good, safe way to do this with out damaging it?
Also, How hard is it to remove the pad? Ideally, I would like to take it off and do it.
Thanks guys, Todd.
Old 03-02-2011, 11:17 AM
Found removal info
I found out how to remove the dash pad. I still would appreciate some input on what to use to safely strip it without damaging the vinyl.
I figure the guy painted it tan because it matched the brown interior and the truck was originally from AZ and considering the heat situation tan is better than black.
Old 03-02-2011, 02:56 PM
Dash pad
Bumped. Anyone know a good way to remove paint from a dash pad without damaging it?
Old 03-24-2011, 10:17 PM
rustranger07's Avatar
rustranger07 rustranger07 is offline
rustranger07 is starting off with a positive reputation.
how did u remove the dash pad?
Old 03-25-2011, 04:49 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
justdashes.com
Old 03-26-2011, 07:59 PM
notmyrealname notmyrealname is offline
notmyrealname is starting off with a positive reputation.
Unfortunately you are kind of screwed. I don't think there is a chemical stripper that will remove the paint without turning your vinyl into a nasty goo. You may want to try carefully sanding the paint off and repainting.
Old 03-26-2011, 08:04 PM
rustranger there are about 14 bolts around the perimeter of the dash that secure it. You have to remove the gauges, ashtray, radio, and glove box to get to them
super duty dash removal todd f. 1999 to 2016 Super Duty 4 08-18-2010 07:05 PM
1986 dash pad mfraley65 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 05-20-2009 03:24 PM
Dash Pad Replaced 1979FordF250 1973 - 1979 F-100 & Larger F-Series Trucks 2 08-07-2006 09:53 AM
M11 front end bcguys 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 09-19-2002 08:26 PM
1966 f100 camper special cosmetics questions tod_1 1961 - 1966 F-100 & Larger F-Series Trucks 11 08-30-2000 08:30 AM
Tags
1966, 1968, 1977, 66, 67, dash, f100, f150, ford, pad, pads, removal, remove, removing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
