Check Engine Light, 2000 Explorer - Ford Truck Enthusiasts Forums
Old 03-13-2003, 09:15 PM
vw_fan17 vw_fan17 is offline
vw_fan17 is starting off with a positive reputation.
Hi, all. Pretty nice set of forums ya got here!
My new girlfriend halfway across the continent (that's a whole 'nother thread in itself ) just had her "check engine" light come on in her 2000 Explorer.
She bought the car used, and didn't get a manual with it (yeah, I know..). I drove it when I visited her, but I didn't look under the hood, and she's not that interested in cars.. It has 4WD, and I'm pretty sure it's a V6, although I have no idea whether it's the OHV or the SOHC.
Anyway - how does the OBD-II connector work with Fords (as you might guess - I have no experience with Fords)? Does it have a user-accessible mode like my Corrado, where if I short 2 terminals, the check engine light will blink out the codes? Or is this strictly a dealer-only item?
Anyone have a link handy to a list of all the codes?
Any advice appreciated.
Thanks in advance.
VW Fan
ps. Not trying to start any flamewars with the name, I've just used it for years..
Old 03-13-2003, 09:21 PM
Diesel_Dummy _ Diesel_Dummy _ is offline
Diesel_Dummy _ is starting off with a positive reputation.
you can get OBDII scanners at autozone exe for under 150 bucks
i'd bet she left the cas cap loose , that will set the light everytime.
Old 03-13-2003, 09:23 PM
Thanks for the tip. Yeah, the gas cap WAS pretty annoying to screw on and off. I'll tell her to check that first!
Not really looking to spend $150 for scanner though - was wondering if there was a cheap (although maybe tedious) way..
VW
Old 03-13-2003, 09:25 PM
no other way to pull codes , i could be wrong, but theres over 5000 OBDII codes and to have the CEL blink that many times would be anoying to try to follow.
check this site out , might be some helpfull info
http://www.batauto.com/
Old 03-13-2003, 10:13 PM
reberhardt reberhardt is offline
reberhardt is starting off with a positive reputation.
Another way to pull the codes is by taking it to Autozone. Most Autozone's will still pull the codes for free. Be sure she writes down the code number and doesn't buy what they try to sell her. Post the codes here and someone will be able to help.
Old 03-13-2003, 10:37 PM
Diesel - the way it works on my Corrado (it's actually pre-OBD2, but has the OBD2 connector) is that you blink one digit at a time, and then tell it to move to the next one when you've written that one down.
5000 codes = 4 digits, so 4 sets of blinks, up to 10 blinks per set. Not that hard to follow, actually. Takes about 3-5 minutes to blink out a code.
Thanks for the suggestion, reberhardt. Ist dass zufaellig ein deutscher Name?
VW
Old 03-14-2003, 11:26 AM
There is no such mode with OBD-II vehicles like the pre-OBD-II vehicles had. The data is stored in the computer and only retreivable by a scanner that can talk to it using the proper protocol. It is in a format similar to a binary format until it gets decoded to a legible format.
My ancestors about 3 generations back are from Germany.
Old 03-14-2003, 12:06 PM
Ah. I didn't realize that the "full" OBD-II had disabled that mode - too bad. I guess I'll have to adapt whenever I sell this one and move up to something newer.. :-(
Thanks for all the tips, guys.
VW
Old 03-15-2003, 12:42 AM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Gotta ask....reberhardt is that your real last name?
My last name ends in hardt too
meine deutsch ist nicht ser gut.
Old 03-17-2003, 11:24 AM
R=Robert
Eberhardt=Eberhardt
i.e. Robert Eberhardt
Old 03-17-2003, 05:27 PM
Racerguy's Avatar
yup that makes sense
Couple of issues with Expedition Redneckfordf2502002 Expedition & Navigator 3 08-12-2014 11:22 PM
94 Explorer with wierd problem Redneckfordf2502002 Explorer, Sport Trac, Mountaineer & Aviator 10 06-13-2014 10:20 AM
Way way OT but I need to rant! AXracer 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 03-06-2014 02:30 PM
96 explorer sport 4.0 shift points please screamersusa Explorer, Sport Trac, Mountaineer & Aviator 2 08-08-2012 12:46 AM
Need To Whine: 2003 VW JETTA TDI - Fuel tank leak, JimmyRC86F150 General Automotive Discussion 15 12-23-2005 07:36 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
