Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-02-2011, 08:33 AM
2002exPSD's Avatar
2002exPSD 2002exPSD is offline
Garage is empty, add now
2002exPSD is gaining momentum as a positive member of FTE.
Wvo 7.3 conversion help needed
My 95 f350 has fuel lines and a valve from the previous owner that had a tank in the bed. I wanna start running a poor mans wvo system. I'm thinking a steel 55 gallon drum in the bed with 2 heaters on it. 1 120 v heater and a 12v heater. Also use an outboard motor inline spin on filter. Would this setup work ok? I'll be running diesel on startup and shutdown and oil once warmed up.
__________________
2002 ford excursion 7.3 diesel 4x4 edge evolution, mbrp 4'' SS straight piped, afe stage 2 true cold air intake with zoodad mod, thruster II turbo, adrenaline hpop, John woods valve body, +8 deep trans pan, 6.0 trans cooler, 6.0 intercooler, rockstar rims with 34" bfg mud terrains, ranchhand grille guard, and one badazz sound system.
2001 ford ranger 4.0 4x4 2003 4.0 swap, dual flowmaster exhaust. Just the work truck
  #2 (permalink)
Old 03-02-2011, 02:01 PM
2002exPSD's Avatar
Anyone have opinions?
__________________
  #3 (permalink)
Old 03-02-2011, 03:44 PM
binuya's Avatar
binuya binuya is online now
binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.binuya has a very good reputation on FTE.
How about trying here? Forums - Powered by Social Strata
There's a lot more SVO user 'traffic' there, and plenty of experts on the subject.
__________________
2001 F250 7.3 CC SB 4x4 Lariat
S&B Intake, MBRP 4" Turbo Back, HPX, AIH Delete, Hutch and Harpoon,
Isspro EV2's, Bilsteins, Warn Premium Hubs, Firestone Bags with Airlift onboard, Fumoto,
Homebrew American Biodiesel (B100 whenever I can)
1995 Mercedes Benz E300D, 2004 Mercedes ML350
  #4 (permalink)
Old 03-08-2011, 12:28 AM
muns53's Avatar
muns53 muns53 is offline
muns53 is starting off with a positive reputation.
You won't get the oil anywhere near hot enough with that setup and you'll damage your expensive motor. You can DIY a good coolant-heated 2-tank system if you don't want to go with a kit like the Vegistroke. More info and help available here: DIY WVO Components - Ford Powerstroke Diesel Forum. Also, use an aluminum tank. Steel reacts with veg oil and polymerizes it, causing a chicken skin to form. This will fluff off and clog your fuel lines, eventually making its way to your injectors, etc.
Tags
1997, 73, conversion, convert, converted, f250, f350, ford, forum, grease, kitford, sale, truck, trucks, wvo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
