00 v10 coil pack bolt broken - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 03-01-2011, 11:47 PM
trucktech trucktech is offline
trucktech is starting off with a positive reputation.
I just got my 00 excursion and was gonna change plugs. It has 104k miles on it and I took 1-7 coils out and when I went to loose #8 and bolt broke flush. Any good ideas for this solution?
Old 03-02-2011, 02:01 AM
Zedrive's Avatar
Zedrive Zedrive is offline
Zedrive is gaining momentum as a positive member of FTE.
I would get left hand fluted drills, the ones which cut counter clockwise, and drill it out.. The bolt may back out while your drilling it hence, the left hand drills. An easy out might work but, I would not want one breaking off in such a small hole. Great trouble then.
I have drilled out afew broken bolts although, not on my Ford. Use a center punch and get it right in the middle, centering the drill bit is crucial. Penetrating oil would be a good idea to use.
Thats how I'd roll.
Old 03-02-2011, 06:32 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Zedrive seems to speak from experience so certainly use his advice about this---sounds reasonable to me. Maybe also use a tap to clean the threads after removal, get a new bolt directly from Ford---about $5 each though.
Use a dab of anti-seize when re-installing too----can't hurt a bit and will prevent this from happening next time.
Old 03-02-2011, 06:57 AM
BigPigDaddy's Avatar
BigPigDaddy BigPigDaddy is offline
BigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to beholdBigPigDaddy is a splendid one to behold
Easy as pie.
Old 03-02-2011, 12:32 PM
Is the bolt a ground for the coil pack or is it just for hold down?
Old 03-02-2011, 01:29 PM
Zedrive's Avatar
I believe it is just a hold down. Also they only torque to 3-4 ft lbs.
BigPigDaddy posted up a better method if you got a welder handy. Either way patience will pay off.
Old 03-02-2011, 04:53 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Pick up the correct size easy out and the specified size left hand drill for the easy out. Center punch the broken bolt in the center and drill down far enough so the easy out can get a grip. The bolt will probably work its way out during the drilling process as Zedrive said. I remove broken bolts all the time with that method.
Old 03-04-2011, 12:51 AM
I drilled it and used a extractor and it broke off inside the drilled out part. So off to the shop it goes (lack of a welder to tack a nut on)
Old 03-04-2011, 02:30 AM
p-nut p-nut is offline
p-nut has a good reputation on FTE.p-nut has a good reputation on FTE.
f- that, run it without the bolt. Use a little di-electric grease around the outside of the plug boot to assist holding it in.
Old 03-04-2011, 05:32 AM
JWA's Avatar
JWA JWA is offline
Quote:
Yeah---WTH you've got 9 other cylinders firing----no need to worry 'bout just one coming loose, losing contact and misfires! Screw it-----don't matter anyway!
Old 03-04-2011, 01:01 PM
it misfires really good with out that bolt in.
Old 03-05-2011, 06:24 AM
There is just something about mechanical advice that starts with "f- that" that makes me think twice. It's even more questionable when your avatar is an Audi emblem.
Just kidding with you p-nut!
Old 03-05-2011, 08:08 AM
F-7's Avatar
F-7 F-7 is offline
F-7 is starting off with a positive reputation.
it is a ground I had the same thing happen to the tee. I made a small bracket and bolted it to the valve cover stud works great. I can post a pic if you like
Old 03-05-2011, 08:38 AM
JWA's Avatar
JWA JWA is offline
Abosolutely just kidding-----but it does make me ask how many of those "professional mechanics" at the stealerships and lube 'n rob quicky oil change places utter that same thing from time to time?
Then again change the rear shocks on an E van and F-That comes to mind repeatedly!
Blackwood rear suspension bobalew 1997 - 2003 F150 1 11-24-2016 03:28 PM
GrifN's 1955 F100 Build GrifN 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 07-16-2015 04:43 PM
suspension replacement for 1978 f150 4x4 F5 DEEG 1973 - 1979 F-100 & Larger F-Series Trucks 11 06-06-2014 05:56 PM
97 4.6 Expedition misfires help gtmustang00 Expedition & Navigator 10 07-09-2013 10:32 PM
Ignition Coil Mounting Hardware TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 5 10-19-2010 03:49 AM
Tags
54, boken, bolt, broke, broken, coil, coils, f150, f250, ford, holds, pack, packs, plug, screw, size, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
