Curt's05, where did you procure those two small bright spot LEDs you installed for map lights in the overhead console? They look very clean and effective. I have tried replacing the original incandescent bulb with different LEDs with less than satisfactory results in the front seat reflector dome sockets. I checked out that Menard's site and found mostly household lamps. Do you have part numbers maybe?
unicornstainless.com, a friend was looking for this type to install into his deck railing and found these. We installed 16 at 3 ft spacing to give the deck/railing mood lighting.
Cheap leds at menards, glued to the hood liner, hooked into the hood switch for over a year now. It helps a lot at night, as we are always looking under the hood!
Where did you splice into the hood light for power. I did mine and I don't think it's turning off when the hood goes down.
TXtinct....looks like you sold someone on here everything needed to swap out all the lights in the car....have enough sitting around to send me a little package also!? Also, where did you get the strip for under the map pocket...is it just a cheap autozone item or is it from somewhere else? Looks great.
I'm on the road right now but I will PM you when I get back. I have plenty.
thats awesome.... i appreciate the help. There are so many different styles/brands/makers out there it is hard to decide what is a quality piece and what is garbage.
Hey ATG_Tuning, you need to enable your Private Messaging so I can send you some info my friend. Under User Control Panel you will be able to take care of that.
