Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 03-01-2011, 01:54 PM
ttttmaxx ttttmaxx is offline
Garage is empty, add now
ttttmaxx is starting off with a positive reputation.
guidance on method?
Guys I made a 20 gallon batch of biodiesel this past weekend and thought I would give magnesol a try. The part of my operation which concerns me is filtering the magnesol or is my system adequate. I mechanically (hand mixed) the magnesol for 15 minutes in my cone tank. After that I let it settle for 24 hours. I then slowly and methodically opened my valve and let the ooze flow until nothing was coming out but bio. This took me over an hour as I wanted to make sure the bulk of the paste was drained. I then pumped (diaphragm pump) the bio into a sock filter bag adapter which I bought at Dudadiesel. I had a 10mic, 5mic and a 0.5 micron in series within the adapter. I regulated the pressure somewhat with ball valves to have a steady slow drainage because I was warned you cant overload the adapter heads with a lot of high pressure. Seem to work fairly good. The end result when visually looking was pretty impressive (to me anyway). My biggest concern in my method was "is it enough filtering?" My last sock filter was a 0.5 micron so I would assume it got at least down to 1 micron. Considering my stock fuel filter in the 7.3 is a 7 micron filter I feel like im in good shape. I have read horror stories (mainly from threads like this one) about not getting enough magnesol filtered out to risk engine damage. IS MY SIMPLE SYSTEM ADEQUATE? Or do I need to go to more elaborate procedure. Im the type person that lives by "the simpler the better". You guys that have been using magnesol for a while, I would sure like to have your honest opinion. Thanks Maxx
__________________
2002 Dually Automatic 2w drive
DP tuner - 60tow, 80econ, 120 race, 140 aggressive
single 7" stack
EGT & Tranny gauges
  #2 (permalink)
Old 03-01-2011, 01:59 PM
Mag.
Quote:
I should add that when I removed the sock filters from the adapter head it was very apparent the 5 micron sock filter did the bulk of the filtering. There was very little residue in the 0.5 micron sock, which made me feel better. Thanks Maxx
__________________
single 7" stack
EGT & Tranny gauges
  #3 (permalink)
Old 03-01-2011, 05:33 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Sounds like you did just fine. Most people that have problems do so by trying to filter before settling. It is impressive just how good the bio looks like after using Magnesol. I've been using it for 6+ years and will never do it any other way...............
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #4 (permalink)
Old 03-02-2011, 08:04 AM
Thanks for your input FABMAN. I was wondering if there would be a greater value having a 48 hour settling period instead of 24 hr? I always like to error on the side of safety. Is it your understanding that 24 hours is all that is needed and that waiting 48 hours is not going to drop any more magnesol out. Thanks again Maxx
__________________
single 7" stack
EGT & Tranny gauges
  #5 (permalink)
Old 03-02-2011, 08:07 AM
1935 Ford pickup
I tried different times when I first started and found 0 difference between 24-48 hours.
You should be ready to go!
__________________
  #6 (permalink)
Old 03-02-2011, 08:12 AM
Thank you very much.........Maxx
__________________
single 7" stack
EGT & Tranny gauges
Tags
05, biodiesel, filter, micron, sock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
