Brake fitting pressure rating? - Ford Truck Enthusiasts Forums
General Automotive Discussion
Old 03-01-2011, 02:07 PM
ghunt's Avatar
ghunt ghunt is offline
ghunt is gaining momentum as a positive member of FTE.
I couldn't find this anywhere else...does anyone know what pressure brake (inverted flare) fittings are rated for, especially brass ones?
I'm trying to cobble together an injector pop tester for my truck's injectors and I don't have a good way to connect the injector line to the rest of the pipe fittings I'm using. The line is 1/4" so I wondered if I could put a 1/4" tube nut on there, flare the line and use an inverted flare to pipe thread fitting.
Max pressure on the system should be 2000 psi or less, I don't know what kind of pressure brake systems can generate, that's why I ask.
Old 03-01-2011, 02:47 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Pressure under normal braking is around 800psi but goes to around 2000psi under heavy braking.
Old 03-01-2011, 04:13 PM
ghunt's Avatar
So is it safe to assume that even brass brake fittings are rated for at least 2000 psi? I've certainly never had one fail...
Old 03-01-2011, 04:50 PM
I`ve never had one fail either, plenty of rusted steel pipes though.
I would think for infrequent use you would be OK.
Old 03-02-2011, 01:36 AM
ford2go's Avatar
ford2go ford2go is offline
ford2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud offord2go has much to be proud of
Did a quick search on "brake line pressure" -- several places talked about 'upwards of 2000 psi'.
Here's a note from some premium replacements for the rubber hose segments -- they test to 3000 psi
Goodridge G-Stop Brakeline Kit.
Sounds like it will work, but it might be worth putting some shields in place to avoid any chance of injury.
Good Luck,
hj
Compression fittings Aluminum only??? underthebridgejim 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 02-17-2016 11:34 AM
97 expy brake lines bubble vs double flare fittings flatheadshoals 1997-2006 Expedition & Navigator 9 11-30-2015 02:34 PM
1968 F250 fuel line fitting Spparky82 1967 - 1972 F-100 & Larger F-Series Trucks 6 08-19-2015 03:40 PM
Aftermarket proportioning valve ronspolv 1973 - 1979 F-100 & Larger F-Series Trucks 7 02-06-2015 12:32 AM
inverted flare? knauert1 1948 - 1956 F1, F100 & Larger F-Series Trucks 0 03-11-2014 03:05 PM
Tags
3, brake, brass, fitting, fittings, flare, inverted, line, power, pressure, psi, ptessure, rating, ratings, steering
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
