Custom Exhaust Question F250 5.4 SD - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 03-01-2011, 12:04 PM
bmarcinek bmarcinek is offline
bmarcinek is starting off with a positive reputation.
Hi All,
I'm in the process of determining what approach to take with putting a new cat back exhaust on my 03 F250 SD 5.4. It has a K&N cold air intake on it and that about sums it up. I'm looking to get some added torque while towing and a decent sound (not something too loud on long trips). Better MPG would be nice on the highway too (getting about 13.5 to 14.5 now).
My thoughts are a Magnaflow or Borla behind the CAT and either exit infront of the rear wheel or in the stock location.
What is my best bet? Pros and Cons to exiting in front of the rear wheel?
Thanks,
Bob
Old 03-01-2011, 12:18 PM
5.4L to Freedom's Avatar
5.4L to Freedom 5.4L to Freedom is offline
5.4L to Freedom has a good reputation on FTE.5.4L to Freedom has a good reputation on FTE.5.4L to Freedom has a good reputation on FTE.
Exit question:
Pros: pipe dont rust out as fast
annoy stupid drivers on the passenger side
looks cool
sounds better IMO
Cons: passengers complain of exhaust noise, driver dont hear it so much
I am quite fond of my gibson exhaust. Based on my research the best thing you can do is eliminate the goofy y pipe.
I still have stock y pipe, no cat and the gibson supertruck exhaust and i noticed it helped the mileage a bit. With my 3.73's, 33's, and a light foot I've been getting about 500-550 miles per tank expressway with some city.
Old 03-01-2011, 12:33 PM
Bigpipes 35's Avatar
Bigpipes 35 Bigpipes 35 is offline
Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.Bigpipes 35 has a spectacular reputation.
The stock exhaust is 3" so you might be better off just changing the muffler I went with a flowmaster 50 series which is just a little louder than stock. I also went with a SPD ypipe which is a must do if you are doing any exhaust work that made the truck sound and feel better.
Old 03-01-2011, 02:29 PM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
Don't expect any real or measurable performance or mileage gains. With your foot in it more, because you like the sound will drop your MPG.
Old 03-01-2011, 02:42 PM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Exiting in front of the rear wheel can get droney and annoying on long trips unless you use a very large muffler. I used to have a lightning style exhaust on my truck so I found out all about it. MPG or performance increase from a catback is little to nothing. I experienced nothing.
A single 3" catback exiting in the stock location is what I would recommend. If your stock exhaust is in good shape yet you can just replace the stock muffler and add a shiny tip to the tailpipe. The Flowmaster 50 SUV muffler will give you more sound but not be overly aggressive. I would recommend replacing the stock y-pipe (where it necks down) with an SPD unit. The stock y-pipe necks down to 1.5" from 2.5" at two places and hurts power. A good custom tune from a place like 5-Star would help give your truck more performance and get the A/F ratio back in line which was thrown off by the intake.
Ford Racing back of cab, side exit exhaust, EB hoaka 2009 - 2014 F150 1 04-20-2015 12:04 AM
Dual Side Exit Exhaust on a 5.4 Garst250SD 1999 to 2016 Super Duty 4 12-23-2011 07:11 PM
dual exhaust for 5.4 mnge03 1999 to 2016 Super Duty 3 05-09-2006 10:39 PM
1997 F150 Exhaust Tail Pipe Exit Recall??? naturalmeddoc 1997 - 2003 F150 5 10-04-2004 08:13 AM
460 dual exhaust fordpower460 Exhaust Systems 3 11-27-2001 04:27 PM
Tags
2010, 54, aftercat, air, custom, duty, exhaust, f250, factory, ford, forum, frod, gibson, intake, super, ypipe
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
