87 Ignition Control Module screws - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-28-2011, 11:33 PM
Thatmetal Thatmetal is offline
Thatmetal is starting off with a positive reputation.
What Kind of screws are holding the ICM to teh distributor on the 2.9 ? Phillips torx etc?
Old 03-01-2011, 06:47 AM
wp120470's Avatar
wp120470 wp120470 is offline
wp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to behold
Not for sure how far back but we used the little ignition wrench i think it was a 5.5mm. They still see them at most parts stores if that is what you have.
Old 03-01-2011, 09:20 AM
tomw tomw is offline
tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.tomw has a very good reputation on FTE.
They are hex head for sure, not Torkx nor Phillips head. The 'socket' body has a very thin sidewall to be able to slip into the hole in the TFI. The "Help" section as some parts stores carry the wrench, with a built-in **** style handle. If you do replace the TFI, make sure to use the heat sink compound, and be careful when you remove and install to move the TFI vertically from the bowl of the distributor. There are connections on the top of the TFI that poke up into a connector on the bottom of the bowl, and the connections can get real wobbly if the internal pickup has gotten rubbery due to age or oil or heat... You CAN get the connectors to work without replacing the internal pickup if you are very careful.
tom
Old 03-01-2011, 03:36 PM
The wrench is an alan wrench right?
Old 03-02-2011, 07:36 AM
wp120470's Avatar
No its like a **** with a thin wall hex head. Go to your parts store and ask them for a Ford Ignition Module Wrench. It should cost around 5 or 6 bucks.
Old 09-19-2015, 11:02 AM
Chasm*18 Chasm*18 is offline
Chasm*18 is starting off with a positive reputation.
This wrench doesn't require you to move the distributor:
CTA Tools 3575 Ford Ignition Module Socket - - Amazon.com CTA Tools 3575 Ford Ignition Module Socket - - Amazon.com
I'm waiting to get mine from Amazon to do this same job. I tried using an OEM ignition module wrench, and it would require me to rotate the distributor, which I prefer not to do.
Old 09-23-2015, 09:51 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
I use a 7/32's that I have turned down to fit in the hole. And yes they make a tool to for this job
Old 09-23-2015, 10:03 PM
I tried using the CTA tool. It easily got the front screw out without moving the distributor. However, I had to rotate the distributor to reach the rear screw. While the tool reached it, there was not enough room between the distributor and the coolant temp sensor housing to make it work. The PO had already marked the distributor position.
The OEM tool is less expensive, and would have worked just as well.
OEM/Ignition module wrench 25013 at AutoZone.com
EXHAUST BOLT REDO moe67moe Excursion - King of SUVs 8 10-13-2016 08:18 PM
Conoco/Phillips To Consolidate Brands pawpaw Oil & Lubrication 0 03-02-2016 02:58 PM
Troubleshooting Light Mounting Rusty_S 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 06-01-2015 11:01 PM
Tags
86, 87, breakdown, control, f150, ford, ign, ignition, kind, module, parts, removing, screws, truck, type, wrench
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
