column shifter - wont start in park?
Old 02-28-2011, 08:26 PM
fyrehose's Avatar
fyrehose
fyrehose is offline
My friends truck has an intermittent starting problem when in park. When in neutral it starts with no problem. Is there some type of contact/switch that wears out in the column? Can you replace it? Part #?
Old 02-28-2011, 08:44 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Is the shifter sloppy? If so tighten the alen head screws. Have someone wiggle the shifter so you can see where it runs into the firewall and you should see the screws/bolts
Old 02-28-2011, 08:49 PM
Damonkr's Avatar
Damonkr
Damonkr is offline
The switch you need to look at is the neutral saftey switch on the side of the transmission. It is black and on the drivers side. Its is easy to see just above the lip of the transmission pan.
The switch has marks on it for clocking it.
It may be as simple as adjusting it. Or cleaning the connection on it.
I just replaced mine got the new one at NAPA I think around $20
To adjust the switch just put the park brake on and put the trans in neutral. Then climb under the truck and make sure the alignment marks on the switch are correctly lined up.
Should look like this when properly aligned.
Old 02-28-2011, 09:02 PM
onelionhunter's Avatar
onelionhunter
onelionhunter is offline
Torx scres
I would pull the cover panel under the steering wheel, then lay flt on the floor so you can look straight up at the steering column where it comes through the dash like john2001 said, there is a plate with 2 torx scres, 90% of the time, they are loose, or have fallen out, just tighten up, and walla, life is good. Just did this to a late 99 2 weeks ago.
Old 02-28-2011, 09:24 PM
fyrehose's Avatar
fyrehose
fyrehose is offline
Thanks for the advice guys!!
Old 02-28-2011, 09:26 PM
JOHN2001's Avatar
JOHN2001
JOHN2001 is offline
Let us know how it goes
Old 03-01-2011, 03:41 AM
SGnAZ's Avatar
SGnAZ
SGnAZ is offline
This wasn't necessary when I did mine,just wedge yourself under the steering wheel and look up.T25 is the size torx you need.
Old 03-01-2011, 10:28 AM
onelionhunter
Wedged
If I wedged myself under the steering wheel, I might still be there now, lol Hope it is just the screws loose, seems to be rather common.
Old 03-01-2011, 12:03 PM
riverrat41's Avatar
riverrat41
riverrat41 is offline
Old 07-20-2013, 10:41 PM
robertbeaulieu28's Avatar
robertbeaulieu28
robertbeaulieu28 is offline
hey, I recently have fixed a friend of mines truck with your solution, but I didn't replace it I put it in neutral and manually with it put it in park and it started up, will it become loose again?? if it does happen does this mean that I have to replace it?
Old 07-20-2013, 10:46 PM
novice psd's Avatar
novice psd
novice psd is offline
Check the torx head screws under the dash first, probably will be your problem, it was mine. It's a easy fix.
Old 07-24-2018, 03:37 PM
Steve_F's Avatar
Steve_F
Steve_F is offline
is there anyway you can post a pic of screws to be tightened? I can see where the shifter is wiggling but not the screws that tighten it. Another comment here says it’s a t25 torx screw so I checked those. They were all right. I just can see the ones that’ll tighten up the shifter
Old 07-24-2018, 03:38 PM
Steve_F's Avatar
Steve_F
Steve_F is offline
Old 07-24-2018, 08:07 PM
MoBill122's Avatar
MoBill122
MoBill122 is offline
Papa Smurf
I tighten the screws on mine about 6 months ago..... and that fixed the no start problem.
Old 07-24-2018, 08:38 PM
Steve_F's Avatar
Steve_F
Steve_F is offline
the screws were tight when I checked them
Bruners4
02-09-2015 11:53 PM
jlasater
37
11-28-2014 10:18 PM
teamlx88
1997-2006 Expedition & Navigator
07-20-2014 01:49 PM
r-kid
03-04-2014 11:12 PM
dtmfman
06-11-2013 08:30 PM
Quick Reply: column shifter - wont start in park?
