Ford 460 to 6 speed
Ford 460 to 6 speed
Hello all,
I found this forum to read about stuff for my dads 08 F250. I am not in the position that I am building my own CJ6 JEEP. I need a power plant for it and I would like an EFI 460. I am just waiting for the right one to pop up. I would also like to use a 6 speed from the Ford Super Duty's.
the ZF SF650. I have googled and searches this site and come up with 'im sure its possible, just need to spend thousands and find out' Im more interested in someone with actual knowledge or info for me. Before I go purchasing trannys and parts. I am almost 100% settled on the 460 but the tranny can change.
Reason for the 6 speed is I need to be able to turn over 37s with 5.13s in the axles while also getting reasonable gas mileage/RPMs on the interstate at 70mph since its going to be driven alot with the nice weather.
Thank you all for any help you can offer.
Ben
Ben
I guess more or less what im asking is, would it be cheaper and easier in the long run to try and cram a diesel in there since it matches the tranny than try and adapt it?
Ben
The following users liked this post:
Ford 460 to 6 speed
In 1963, I very successfully installed a Ford 390 in a CJ6. I used a Ford T10 4-speed transmission, and the stock transfer case. I purchased the CJ6 new, so opted for 4.27 axles, which worked out great. I also installed an overdrive from a 1950 Studebaker which only worked in 2 wheel drive. I purchased the transmission mainshaft to adapt from the T10 to the transfer case from one of the hot rod parts suppliers of the time, I believe it was Brian Chuchua, but I could be wrong. This was a very inexpensive conversion, that worked out really well. I put about 80,000 miles on this vehicle, and (since I used to be **** about car costs) got an average of 13.5 mpg during this period. It was fun!!!
The 460 zf5 didnt have that low 1st gear. At the time they had the zf5-42 and had a mid 4 1st. The stroke -47 model had the lower 5.72 1st gear. That being said, Id suggest a t19 with a gv od or an idi diesel with the zf5-47. Ill say one last thing, this is from months almost years of research but no expiriance. I havent found anyone who has done a zf6 behind a bbf because they dont share bolt patterns.
I'm a little confused... I have the 460/5spd with 4.10 rear gears and running 39" Mickeys. 1st gear is a creeper gear, and I can pull a Boeing 747 with it, and I can run 70mph without even breathing hard. So why the 5.13 gears? Are you doing some mountain climbing or rock crawling?
zf 5speed simple! But?
your other option is the TCI 6speed auto. can make it a manual automatic i guess and a divorced transfercase. Kinda expensive but they make with a detachable bellhousing for big block ford or small or dodge, you get the idea! something else to consider. just did a zf 5 speed to a 400 ford and lots of work and thinking to make happen. considered the 460 but wanted a little better fuel mileage and used the 400 with some serious upgrades. good luck! trick to fuel mileage is less weight and tall skinny tire. less rolling resistance. good luck!
I have the ZF-5 in my 96 with the 460. I used to run on 39" Mickeys, which actually stood about 36.5". It was more than adequate with the stock 4.10 gears, but now the truck has 42" Swampers, and it's going to need a lower gear set with those tires....
If you want to run an EFI gas engine with the 6 spd. I would suggest a 5.4L. It's easy to strap on a blower for big power, and it will fit in a Jeep.
The 385 engine family (370, 429 and 460) have the same block bolt pattern. The mid-90's Ford medium duty trucks used the 429 with a 13" clutch and an Eaton-Fuller 5 speed O/D trans. The FSO-6406A is a 6 speed O/D synchro transmission that is a direct bolt in. No adapters no fussing around. I've had one in my 2001 Dodge 3500 since 2008. Not an issue with any loads and I haul Heavy.
I am putting together a 1994 Ford F-450 with a 460 in it. The E4OD is dead and I'll be putting in a Fuller Transmission. Lots of parts out there and very reasonable.
Psycho_bob_1977
249
11-18-2019 08:34 PM
YF22Jet
09-16-2017 01:15 PM
4x4slik
02-18-2016 08:55 AM
