Can I buy Mounting Brackets for Bucket Seat Conversion? (96 F-250) - Ford Truck Enthusiasts Forums
Old 02-28-2011, 07:55 PM
DieselFordLoversWife DieselFordLoversWife is offline
DieselFordLoversWife is starting off with a positive reputation.
Question Can I buy Mounting Brackets for Bucket Seat Conversion? (96 F-250)
I have a 96 F-250 Extra Cab. It had a bench in the front and we finally found a set of bucket seats for it. (Taken from another 96 extra cab.)
Problem is, the bolt patterns are different. The guy we bought them from told us to drill extra holes through the floor. The idea of adding extra holes to the frame sounds pretty stupid, I don't want to weaken the body, or give it the option to rust. (Our shop agrees w/ this thinking.)
Anyway, we talked to some people who said to just weld together some metal, anchor it to the old holes, and appropriately space new holes in this frame.
My question, is there somewhere I can buy pre-made brackets or frame for this purpose? I am concerned of the safety and functionality of a thrown together frame. And I need this immediately.
Thank you!!
Old 02-28-2011, 11:37 PM
Ed Bamba Ed Bamba is online now
Ed Bamba is starting off with a positive reputation.
I replied to your other thread a while back. The shop that installed my seats just drilled the required holes in the floor board that match the captain's seat frame. They used a wide plate with a nut welded to it and placed it under the floor. One of the plates would get loose at times, but after applying more torque to the screw/bolt, it hasn't loosen up since. The existing holes were plugged with the original bolts.
My truck had an a option for factory captain's chairs, and they likely had the same floor as the 92-96 trucks, but I can't guarantee that. So the floor area your concerned about should already have extra support. If not, the wide nut plate I mentioned above should be a sufficient substitute for the factory plate. I haven't noticed any stress cracks at the new seat frame holes.
As far as the risk of corrosion, you just need to coat the bolt holes with an anti-corrosion coating, or sealed with some type of panel sealant (i.e. silicone or RTV, etc.)
I fully understand all your concerns, but with the proper mounting plate and sealant, you should be good-to-go.
BTW, not sure if there is a bolt-on, pre-made bracket for your application.
HTH,
Ed
Old 02-28-2011, 11:48 PM
Thanks Ed, I appreciate the info.
Old 11-01-2014, 07:27 AM
bigkid48 bigkid48 is offline
bigkid48 is starting off with a positive reputation.
summit has them for 90 bucks apiece
Old 11-01-2014, 08:03 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Quote:
Thanks for bring up a DEAD thread from3 years ago, but you are STILL going to drill holes
Old 11-01-2014, 01:15 PM
fordboy97's Avatar
fordboy97 fordboy97 is offline
fordboy97 is starting off with a positive reputation.
Why do people get worked up when someone replies to an old thread? I don't get it
Tanner
Old 11-01-2014, 01:22 PM
Quote:
Tanner
Well since the question was already answered and with a MUCH better solution.....
How determine if 92'-96' F250 is HD or LD? abosely 1987 - 1996 F150 & Larger F-Series Trucks 5 12-03-2015 10:16 PM
seat covers cobra1gt 1987 - 1996 F150 & Larger F-Series Trucks 3 11-24-2015 08:31 PM
Bucket Seat Woes LipschitzWrath 1973 - 1979 F-100 & Larger F-Series Trucks 13 09-15-2015 01:38 PM
Recommendations for seats please 96 F250 Extra Cab DieselFordLoversWife 1987 - 1996 F150 & Larger F-Series Trucks 10 04-19-2015 08:11 PM
75' super cab bucket seats tex2046 1973 - 1979 F-100 & Larger F-Series Trucks 3 04-03-2007 09:40 AM
Tags
1996, 1997, 91, 9296, 96, bracets, bucket, buy, cani, conversion, f150, f250, rear, seat, seats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
