Defective fuel injectors - replace 2 or all 8 - Ford Truck Enthusiasts Forums
Old 02-28-2011, 05:56 PM
lhansman lhansman is offline
lhansman is starting off with a positive reputation.
After replacing my FICM and the 5 components with O-rings for the oil to the fuel injectors in November I noticed my '04 6.0 was running a little rough when first started a couple of weeks ago. It felt like the same issue I had prior to replacing the FICM so I took the truck to the dealer and they tell me that I have a mechanical problem with one injector on each side and they are quoting me a little over $2,000 to replace these two.
My truck has almost 290,000 kms on it and I believe these are the first injectors to be replaced. I have had the truck since 105,000 kms and have given it generous amounts of Power Service at each fueling - not to mention the many, many $$$ in repairs.
My thoughts are that at this mileage I should replace all 8 but to have the dealer do it brings the cost close to $5,000. So I am considering using injectors from another source that might also give me a little additional performance. I have had the EGR deleted on my truck, run the SCT tuner and have a MBRP 4" exhaust and after I had all this work done really started to enjoy the truck. I do not want to affect the longevity/reliability of my truck so I am not looking for huge power - especially since I do not have ARP studs installed yet. It has been suggested that I install injectors that would give me a little power boost and also install an AirDog system. I could replace all 8 injectors and have the AirDog installed for around $3,000.
Who makes and installs good fuel injectors for the 6.0 and do you recommend the AirDog system?
Unfortunately I do not have the knowledge to contribute much to this forum but I certainly appreciate and have benefited immensely from the contributors so any insight would be appreciated.
Old 02-28-2011, 07:04 PM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
With your mileage I'd go right back with stock injectors from FORD. You can buy the 8 injectors for $220 each with a 12 month warranty and an air dog for about $700 +/- and have them installed at an independant shop for not much more.
Who are the injectors coming from? I know most if not all of the reputable injector dealers. This is NOT somewhere you want to go cheap.
Old 02-28-2011, 07:20 PM
dayooper dayooper is offline
dayooper is starting off with a positive reputation.
do all 8 if 2 are going the rest aren't to far behind
Old 02-28-2011, 08:02 PM
rdunagan's Avatar
rdunagan rdunagan is offline
rdunagan is gaining momentum as a positive member of FTE.rdunagan is gaining momentum as a positive member of FTE.
id go with arp studs before you think about higher performance injectors. your asking to blow the heads off of it if you put them in before studs. but if you want a good company for injectors id say industrial injection. thats where im getting mine from down the road. i personally wouldnt go with rcd being all the bad stories ive heard and seen a buddy go through IMO and yes i would recommend the airdog II great thing to have!!!
Old 03-01-2011, 04:19 AM
Although I live in Canada I actually had the previous work done at RCD and so was considering their injectors but thanks for the warning.
My local dealer is quoting me around $383 per injector - where can I fin the ford ones for $220? The CDN$ is at or slightly above par so that is a great savings. I am very happy with the current performance so new factory injectors would be fine at this lower price.
I'll try the AirDog also I think. For a fairly stock truck like mine is the regular AirDog OK or should I go with the AirDog II?
Old 03-01-2011, 04:22 AM
One other question - I have been considering the ARP head studs. In fact I wanted to do them when the dealer had the heads off after my second EGR failure but because the work was being done under warranty they would not install non Ford parts. since the valve covers will be off anyway to change the injectors is it possible to install ARP studs without having to lift the cab off the truck?
Old 03-01-2011, 05:17 AM
Tousley Ford has them listed at $220 on their website. Since you're in Canada it might be cost prohibitive to ship back and forth (cores) though. Still.........it will be "new" Ford injectors in my truck when it's time.
Old 03-01-2011, 09:58 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
I had two go bad last spring, replaced just those two and it ran like a top until it was wrecked this fall. When I rebuild I'll probably keep the injectors I currently have.
Old 03-01-2011, 10:42 AM
smokersteve's Avatar
smokersteve smokersteve is offline
smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.smokersteve has a good reputation on FTE.
Here are some injector links.
$179
Diesel Care Inc
$179
2004-06 Ford F Series 6.0L Diesel Fuel Injector OEM Fuel Injectors, Diesel Fuel Injectors
$179
Results for Diesel Injectors:Ford
$189
KT Performance
You may find them cheaper if you search for international injectors, vt365 is what international calls our engine.
Old 04-27-2011, 03:26 PM
hoper9496 hoper9496 is offline
hoper9496 is starting off with a positive reputation.
I know that injector 2 4 5 and 8 are bad. How do I replace them myself? Is it hard or should I have someone else do it?
Old 04-28-2011, 04:38 AM
Thanks for your responses all. I still have not bit the bullet to spend the money on replacing all of my injectors. I negotiated a much better package price with my dealer to do all eight but am still looking at close to $4,000 with taxes. I am within a couple of hours of Buffalo or Detroit so I may see if a US dealer can do the whole job at a better price.
Thanks again. As a first time Ford owner, this forum has been invaluable with diagnosing the many problems I have had with my 6.0 diesel.
Old 04-28-2011, 11:19 AM
brickie's Avatar
brickie brickie is offline
brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.brickie has a spectacular reputation.
Four thousand for a set of injectors is insane!It can easily be done in one day by someone with experience.
Old 04-28-2011, 11:28 AM
Dealer prices... 8 injectors runs about $2200 US, add a days labor (I don't know exact rates) and you're close to $3k US.
Old 04-28-2011, 11:43 AM
Fordnatic68's Avatar
Fordnatic68 Fordnatic68 is offline
Fordnatic68 is starting off with a positive reputation.
Guys seriously run some revx or hotshot secret thru it first. Dimes to donuts theyre probably sufferin from stiction. Why spend 2-3 k when you can spend 50 bucks? N if you have to buyem Tousely ford even if your in canada but be patient cause the border tards think everything is from japan and is radioactive. I waited a month for my order.
Old 04-28-2011, 11:54 AM
steelhead2's Avatar
steelhead2 steelhead2 is offline
steelhead2 has a good reputation on FTE.steelhead2 has a good reputation on FTE.
Quote:
2,4,8 won't be bad,but 5 could be a pain.not hard if you're mechanically inclined.check the tech folder for some good info on it.
Airdog and Injector Question chrisbrady498 6.0L Power Stroke Diesel 17 04-11-2016 03:56 PM
Fuel system maintenance/upgrades the_auto_tech 6.0L Power Stroke Diesel 5 01-20-2015 02:26 PM
Airdog II 165 gpm CHASE0122 1999 - 2003 7.3L Power Stroke Diesel 2 02-28-2014 12:59 PM
Fuel system maintenance and upgrades - complete list the_auto_tech 6.0L Power Stroke Diesel 31 07-05-2013 10:38 AM
2002 replaced injector, runs really bad Rigormortise 1999 - 2003 7.3L Power Stroke Diesel 60 04-30-2013 07:30 AM
Tags
2005, 2006, change, cost, diesel, f250, f350, ford, fuel, injector, injectors, mileage, replace, replacing, time
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
