Where to buy Diapco return line kits? - Page 2 - Ford Truck Enthusiasts Forums
Old 04-13-2014, 06:27 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT FORDF250HDXLT is offline
FORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant futureFORDF250HDXLT has a brilliant future
Quote:
Originally Posted by FORDF250HDXLT View Post
i just installed this kit today,and its loads better than those two kits i got from pensacola.
i noticed they included real fuel hose with this one! not that braided type stuff that kept leaking on me.
the same hose i ran from and too my fuel tanks.
diesel rated goodyear SAE 30R7.
Fuel Line/PCV/Emission Control Hose SAE 30R7 | GoodyearŽ Engineered Products
i was pleased to see that.
too bad it didn't included Viton o-rings or it would be perfect.i tossed the standard ones and went with Viton again as my last Vitons were the only part that didn't leak.
anyway.looks like a decent affordable kit.
these are sold at oreilly's too.make sure to get the correct kit.year specific for your truck.
^ still leak free.i did replace it again due to installing a set of new g code injectors.i used the same kit,and just as issue free as the first one.
Viton O-Ring, 75A Durometer, Round, Brown: O Ring Seals: Amazon.com: Industrial & Scientific Viton O-Ring, 75A Durometer, Round, Brown: O Ring Seals: Amazon.com: Industrial & Scientific
^ enter dash size: 111 - check it - then hit apply.
111 7/16" 5/8" 3/32" 0.424" 0.63" 0.103" 50
this is the one for the older idi's
Amazon.com: Delphi 7135-264 Fuel Injector Installation Kit: Automotive Amazon.com: Delphi 7135-264 Fuel Injector Installation Kit: Automotive
under 40 bucks for years of no leaks.nothing wrong with that.
Old 11-04-2015, 03:54 PM
transmogrifiednow's Avatar
transmogrifiednow transmogrifiednow is offline
transmogrifiednow is starting off with a positive reputation.
Perfect
This thread is perfect for those like me who are going to do their first fuel return line swap. A lot of those old links don't work anymore, but the amazon ones for the Delphi still work. Just ordered it and some viton o-rings so I can quit leaking fuel. Not sure if I should drive it like this though. I reckon that a return line leak isn't life-threatening, right? Diesel running over the top of the engine and down by the flywheel shouldn't cause any fires or anything, right? Diesel being not as volatile as gas?
Old 11-05-2015, 07:51 AM
typefour's Avatar
typefour typefour is offline
typefour is starting off with a positive reputation.
I stock dipaco always and supply viton orings and new olives with each kit.
Old 11-05-2015, 08:09 AM
Already bought the kit from Amazon. They don't sell olives though. Can you sell olives by themselves?
Old 11-07-2015, 07:59 AM
GreenMtnMan's Avatar
GreenMtnMan GreenMtnMan is offline
GreenMtnMan is gaining momentum as a positive member of FTE.
Here's a tip from a novice mechanic: when you put the new O rings on the injectors, put the top one on first, the bottom one will go over it to where it has to be. I've had my return lines on now for almost ten years. I keep thinking I should replace them now, but I don't want to mess with a good thing! When you work under the hood be careful not to bump any of the components.
Old 11-07-2015, 10:52 PM
Thx
I just did them and I discovered that trick too. It would be really hard to try and get that o-ring all the way down. Much easier to do the top one first! Now, on to the freakin' fuel filter leak that just showed up! Dadgummit! Hopefully its just an oring and I don't have to plug it or buy the rip off new one. $145 for a small metal plate mated to a plastic receptacle? There has to be a cheaper way to sell those.
Old 11-08-2015, 08:55 AM
bashby's Avatar
bashby bashby is offline
bashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to allbashby is a name known to all
Are you talking about fhe fuel heater on top of the filter head leaking? The heater is worthless. A lot of us have removed it and replaced it with a 1/4"npt plug. You need to remove the heater and tap the hole. You can also just replace the o rings.
Old 11-08-2015, 05:07 PM
typefour's Avatar
Quote:
Yes I do. I will be gone this coming week though.
Old 11-08-2015, 05:24 PM
bashby's Avatar
I got olives at an International dealer. They had them in stock.
The guy had no idea what I meant when I asked for olives for a 7.3
But was able to look them up.
Old 10-08-2016, 08:07 PM
DJHoff's Avatar
DJHoff DJHoff is offline
DJHoff is starting off with a positive reputation.
Noticed this to be the most recent post regarding replacing Return lines with a Dipaco Kit. They are very difficult to find. I have 2 complete unopened Kits I will sell for $35. each postage paid. Contact me for arrangements to purchase.
Buy DEF CR3999! 6.7L Power Stroke Diesel 16 06-06-2016 10:12 AM
Gem module Glenn Fisher 1999 to 2016 Super Duty 3 03-29-2016 11:59 PM
PLASMA LED for the X - WHERE to BUY munireusa Excursion - King of SUVs 16 03-03-2016 04:52 PM
Power door lock actuators-where 2 buy z 97ford1 1997 - 2003 F150 3 01-06-2016 09:49 PM
Coolant bottle oxt127 6.0L Power Stroke Diesel 1 05-22-2015 12:52 PM
Tags
73, 73120, 73l, 88, cap, caps, diapco, ford, fuel, idi, injector, kit, line, offset, return, straight, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
