Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 02-28-2011, 01:18 PM
Chuggster Chuggster is offline
Garage is empty, add now
Chuggster is starting off with a positive reputation.
Power tilt does not work and won't shift from park
A few days ago the power tilt quit working on my 07 Nav. And just yesterday I had problems getting it out of park a few times. I kept trying and eventually it would not go at all. I hit the brake and the lever on the shift **** will not go in to shift into gear. It runs and starts fine. I had to take the little cover off by the shifter and push the little button down to override it to shift into drive. I can not find anything wrong so far. When I pull the lever on the shift **** I can hear a switch or relay in the steering column click. Is there a relay that controls the power tilt and the shifter?
  #2 (permalink)
Old 02-28-2011, 01:52 PM
I just found that the brake lights are not lighting up. I hit the brakes over and over and finally when they lit up it would shift to drive. But then when trying again the brake lights do not light. I checked 2 fuses under the hood that were for the brake lights and they were good. Please help.
  #3 (permalink)
Old 03-01-2011, 08:55 AM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
I would check the switch by the pedal.
__________________
See ya,
Eric
  #4 (permalink)
Old 03-01-2011, 08:59 AM
That's what I was hoping. I picked up 2 different brake switches this morning. What about the power tilt? It is stuck in the way up position.
Tags
2007, button, drive, expedition, ford, lever, lincoln, navigator, navugator, park, power, shift, steering, tilt, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
