1989 F-150 warm starting problem - Ford Truck Enthusiasts Forums
Old 02-28-2011, 01:06 PM
badkins50 badkins50 is offline
badkins50 is starting off with a positive reputation.
Alittle history - My G-PA bought the truck brand new in 89. It now has 15K original miles on the factory engine. Yeah only 15K miles. Never seen any bad weather. He passed away in 05 and now G-MA wants us to drive it. It is a 1989 XLT Lariet with the straight 6 EFI, automatic with 2 fuel tanks.
The problem - starts better than new when the engine is cool completely down. When starting the engine warmed up it cranks about 10-15 times before firing up. The thing runs great when started and not a single check engine light to be seen at all.
Other than regular maintenance the only work that has been done is we had the injectors and throttle body cleaned at the dealer back in (I think) 2006.
Can anyone help me with possible problems we can look into to get this beauty back on the road for a daily driver (well at least when the weather permits). Thanks in advance for all your help.
Old 02-28-2011, 01:12 PM
Duct Tape Racing's Avatar
Duct Tape Racing Duct Tape Racing is offline
Duct Tape Racing is gaining momentum as a positive member of FTE.
cap rotor plugs wires? sounds like a tune up issue
Old 02-28-2011, 01:32 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
I predict you need a new ignition coil.
Old 02-28-2011, 06:00 PM
drjoe171 drjoe171 is offline
drjoe171 is starting off with a positive reputation.
I would be tempted to heat things up one at a time with a hairdryer.
With the engine cold, and you Know it will start, hit, say, the distributor with a hairdryer toi heat it up, then the ignition coil, then the ignition module until it won't start.
You can also cool down components with compressed air, one at a time.
There was a guy on here who heated his distributor like this, NO start.
Cooled it with compressed air, and it would start.
He did that a couple times and THEN replaced whatever it is inside the distributor knowing for sure it was that particular heat related part failure.
Old 02-28-2011, 06:05 PM
drew92472 drew92472 is offline
drew92472 is starting off with a positive reputation.
Check the spark hot with a simple $3 tester from the parts store the little screw apart kind or one that picks up thru the wire,, probably the pickup coil or module in distributer
Old 03-01-2011, 01:46 AM
skelator84 skelator84 is offline
skelator84 is starting off with a positive reputation.
do both fuel tanks work?
Old 03-01-2011, 08:29 AM
All great things to take a look at. After pricing all these parts, and after the truck sitting for long periods of time, I going to go ahead and replace all these parts and give it a try. I Figure it would be money well spent anyway. Hopefully I will be able to get in that garage and start at it this weekend. Thanks for the advice and I'll keep you posted.
Quote:
Yeah both tanks are working fine. You can switch tanks and everything runs great. Also when you go to start you can hear the fuel pump working no matter which tank is on. Is there something else with the tank I should look for?
Old 04-18-2011, 07:34 AM
Quote:
Finally had some time and the weather was cooperating so went to the garage and starting working on this issue. Changed the plugs, wires, cap, rotor, fuel filter, oil and filter, some seafoam and cleaned out the throttle body. Started up and ran for a while, waited 5 minutes, started right up. repeated again and it started right up with no problem. I think its time for a nice long drive out into the country to blow the cob webs off (and out).
Thanks for all your help.
Runs fine cold, but rough when warmed up VanAwful 1999 - 2003 7.3L Power Stroke Diesel 18 06-01-2014 01:42 PM
1989 Ford F150 Starting Problems. SamanthaFl 1987 - 1996 F150 & Larger F-Series Trucks 5 03-09-2008 03:55 AM
1989 Ranger 2.3 Oil Pressure Question? kochy54 Ranger & B-Series 15 11-22-2006 07:21 PM
bucking, misfiring, etc. falcon26 Ford Inline Six, 200, 250, 4.9L / 300 13 08-16-2002 12:28 PM
1989 F250 Rough Idle cant fix so far MF15 1987 - 1996 F150 & Larger F-Series Trucks 5 03-25-2002 12:25 PM
Tags
150, 1989, f150, ford, problems, starting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
