Carter YF vacuum ports [vacuum timing adjustment] - Ford Truck Enthusiasts Forums
Old 02-28-2011, 10:14 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Recently, my 1986 F150 with 4.9L and duraspark conversion has been pinging with less than moderate throttle on various gasoline brands, so I decided to adjust the timing [retard]. After plugging the disconnected distributor vacuum line and connecting a vacuum gauge to a manifold port, the vacuum was 21" Hg. I tested maximum vacuum and obtained 21.5". I believe our elevation here is in the 400 ft range [north Alabama]. I retarded the distributor and lowered the vacuum reading to 19.5" and then had to adjust the idle speed. The "normal" idle speed, for me, is 750 RPM, but after retarding the timing, the speed dropped to less than 500 RPM [by the way, this truck has a manual transmission]. The test drive revealed no pinging at all. Soon, I will split the difference and adjust to 20 or 20.5" and retest, so I can find the "sweet spot". It sure was nice to be able to accelerate and NOT hear pinging!
By the way, on the carburetor I have, there are three vacuum ports on the passenger side, as mounted. They are lined up in sort of a wide "V". The one closest to the front of the engine is where my vacuum advance is attached. I decided to test each port and this is what I found: The front one, has no vacuum at idle and when one blips the throttle, the gauge barely moves and seems to significantly lag behind throttle opening [it may have shown 2-5" Hg with a quick blip]. The rear most port [at top of "V"], also has zero vacuum at idle, but quickly responds to throttle opening with a very wide swing. The middle port [bottom of "V"] has ~5" Hg at idle and does not seem to vary when the throttle is quickly opened.
As an experiment, I connected the distributor vacuum line to the rear most port and tried to drive. The truck bucked abruptly any time the throttle was applied from low speed. Apparantly, the vacuum is applied too quickly.
Just sharing as food for thought. Have a good day!
Old 02-28-2011, 11:18 AM
krazeyelf's Avatar
krazeyelf krazeyelf is offline
krazeyelf is starting off with a positive reputation.
I appreciate this post, and if anyone can provide detailed steps or links to instructions for vacuum/timing/tuning, I would appreciate it (mine's an '81 4.9). After tracking down a bunch of minor problems, I'm ready to move on to tuning this thing right. I get a little pinging/knocking and I'm sure it's timing related. My idle is also uneven and misses just a little. I plan to replace the voltage regulator by next weekend do to some gauge/light flickering/dimming. One thing I notice right now is that my RPMs are low where I want them to be after I start, but after driving around a while, it idles closer to 1000 (much higher than I want). If I shut the truck off and restart, the idle drops back down closer to what I want. Perfectionist that I am, I want to get this rebuilt motor sounding purring like a kitten.
Old 02-28-2011, 04:26 PM
Harte3 Harte3 is offline
Harte3 is gaining momentum as a positive member of FTE.Harte3 is gaining momentum as a positive member of FTE.
Reading your vacuum gauge: Reading your vacuum gauge
Old 02-28-2011, 06:16 PM
krazeyelf's Avatar
Quote:
Thank you for that! People on this site have the coolest facts, advice, and tips.
Old 02-28-2011, 06:31 PM
teds74ford's Avatar
teds74ford teds74ford is offline
teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.teds74ford has a good reputation on FTE.
1986- thanks for posting your findings!
I have found that by setting the straight (disconnected vacuum) timing at 8 I get the best overall tune. Then I tune by max vacuum on the gauge and reconnect everything.
Old 02-24-2013, 03:03 AM
pegasus867 pegasus867 is offline
pegasus867 is starting off with a positive reputation.
Hello,Need Help Carter Carburetor Vacuum Lines
Hi!
I apologize because I need help for my '77 Ford Maverick ( I Know it is not a truck) but it was hit by one truck 1 year ago, due to the crash all the plastic hoses and wires in the engine compartment were burned and melt, now after a year of weekend after weekend rebuilding it, the car finally started but if I try to accelerate fast, the engine stop and I am think that the vacuum hoses are not connected where must be or the carburetor (Carter YF) is getting excess of air because if I close the top plate and only let a 1/4" wide gap, the car can run well but with very bad fuel economy, may somebody help me?
thanks in advance
pegasus867
Old 02-24-2013, 07:44 AM
rustywheel68 rustywheel68 is offline
rustywheel68 is starting off with a positive reputation.
Quote:
you'd be better off starting a new thread-
but yes, it does sound like you may have a vacuum leak.
re-read the first post in this thread- if you have the same carb, all the ports that the original poster is talking about must be connected to something or simply plugged.
Old 02-24-2013, 07:47 AM
Quote:
if it was only pinging at less-than-moderate-throttle, why not just dial back on the vacuum advance, instead of pulling your initial setting down?
Old 02-25-2013, 07:25 AM
Labhound Labhound is offline
Labhound is starting off with a positive reputation.
I always set the timing "by ear"....
Old 02-25-2013, 12:12 PM
Quote:
i hear this one a lot (along with "time by vacuum").
that'll work, as long as you're only concerned with the initial timing...
Old 02-25-2013, 01:21 PM
X2 on what rusty said. I use vacuum for initial timing and carb adjustment...as a starting point in the tuning process.
Vacuum leak detection - effective and inexpensive. 1986F150six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 13 03-13-2017 09:30 AM
Vacuum advance 101 winginit 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 70 11-09-2016 11:15 PM
Ported or manifold vacuum - personal observation. 1986F150six 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 04-20-2015 09:32 AM
Ported Vacuum, how it changes with throttle/rpm 1975FordF250 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 06-24-2014 09:06 PM
Vacuum line FAQ f100beatertruck 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 11 07-29-2013 07:41 PM
Tags
1986, 300, 49, 6l, 81, adjust, adjustment, adjustments, advance, carb, carter, ford, timing, vacuum, yf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
