Oil around intake clamps of turbo - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-28-2011, 08:48 AM
redbug's Avatar
redbug redbug is offline
redbug is starting off with a positive reputation.
Hello,
I have a 2001 7.3 and I just changed the oil. While under the hood I noticed a lot of black oily deposits around the intake rubber and clamps going into the turbo. It was on the black rubber connector that says cool air? There was also some spray on a few tubes under the pipe.
When I was looking for a 7.3 truck I noticed that a few others had a bunch of black crud in the same area. This is obviously common. What is the issue and how do I repair it?
Thanks,
redbug
Old 02-28-2011, 08:52 AM
mtdigger's Avatar
mtdigger mtdigger is offline
mtdigger is starting off with a positive reputation.
Search CCV mod..install, degrease engine,Install new ic boots....worked for me
Old 02-28-2011, 08:57 AM
riverrat41's Avatar
riverrat41 riverrat41 is offline
riverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to beholdriverrat41 is a splendid one to behold
He is right.The factory hoses are really thin and known to leak oil and lower boost.You can fix them easily with a few mods.Look here.Give Clay a call and tell him what you need.
Riffraff Diesel: CCV Kit
Riffraff Diesel: RDP Complete CAC Intercooler Boot Kit
Old 02-28-2011, 08:59 AM
woodnthings's Avatar
woodnthings woodnthings is offline
woodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud ofwoodnthings has much to be proud of
The residue comes from the Crankcase Ventilation (CCV). The design is to have the CCV vent into the intake air to get consumed by the engine and hopefully lower emissions. Since the boots are pre-combustion the oil eventually gets absorbed or blown through the connection and starts to make a mess. The CCV mod redirects the oily air through a hose to ambient under the truck. Most of the International trucks use this type of system exclusively. Ford designed it to be consumed to keep the EPA off of their back.
Removing the boots and cleaning them, will keep it at bay for awhile, but it will most likely come back. If you do he CCV you will need to remove the boots and clean them really good before re-installing. This will get all the residual fluid.
Old 02-28-2011, 09:02 AM
ChunderDownUnder's Avatar
ChunderDownUnder ChunderDownUnder is offline
ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.ChunderDownUnder has a great reputation on FTE.
if your talking bout this. it is due to the crank case vent being routed into the air intake.
no biggy they all do it. your intercooler tubes end up with a oily residue inside
if it troubles you you can do the CCV mod
Riffraff Diesel: RDP CCV Kit
I went with another supplier but here it is installed. It re routes the CCV gas, filters it and returns clean air back to your intake.
while you are there wack a new set of boots on and you wont look back
looks like Im to slow, they all beat me to it.
Old 02-28-2011, 09:06 AM
mtdigger's Avatar
Also check guzzles mod page, he made a cool catch can to keep the goop from ruining your driveway....excellent idea unless you park in the dirt ! Good luck, riffraff has a nice kit, if you're not into making your own
Old 02-28-2011, 09:09 AM
mtdigger's Avatar
Sorry chunder...its raining and I'm bored at work ! Didn't mean to jump the reply gun
Old 02-28-2011, 09:16 AM
Quote:
no probs m8, its 1 am in the morning here I should be in bed.
Old 02-28-2011, 09:49 AM
mtdigger's Avatar
Cool.... so I guess since I'm talking with you....technically...I'm a time traveller....BTW..my ic boots weren't nearly that cruddy...wow ! But my 99.5 only has 36,000 miles
Old 02-28-2011, 10:30 AM
SkySkiJason's Avatar
SkySkiJason SkySkiJason is offline
SkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant futureSkySkiJason has a brilliant future
I did the CCV 'delete' for a little while. I absolutely hated it. I love my diesel truck, but that stinky CC smell was horrid and the smoke made people think something was wrong with my truck. Screw that 'mod'!!
As far as 'CCV mod' goes, I can't see it reducing the oil on/around boots very much unless you replace CAC. I recently had CAC out for the 3rd time (at least...) and stood it on end intentionally trying to drain the oil from it - again. After 3 weeks, there was STILL oil coming out. This oil (which ain't hurting a damn thing) will always migrate thru the seal on the boots - even if ya stop 'adding' oil to the CAC. I can say that upgrading to RiffRaff boots does stop ALOT of that migration and since I've been using them all it takes is a couple squirts of diluted Purple Power and a blast from the hose a couple times a year and my engine stays almost as clean as Rick's (Miller_Feed). Of course, if ya want an engine THAT clean - you gotta avoid driving in inclement weather... (Btw, Rick does not have a CCV mod )
Old 02-28-2011, 10:45 AM
If you want to spend a little dough, you can get the BD Diesel CCV system. Kind of spendy, but has a nice professional look.
Old 02-28-2011, 10:46 AM
mtdigger's Avatar
Id prefer to keep the ccv as well, but there's got to be a way to vent it into the manifold to avoid it being run thru the ic system..no ? Has anyone tried that ? My dad is trying to figure a way to do it
Old 02-28-2011, 10:50 AM
mtdigger's Avatar
Didn't the old gas v8s just route it under the carb ? It's been awhile...
Old 02-28-2011, 11:34 AM
Some weld a pipe into the exhaust at an angle. The exhaust flow will pull the CCV air into the exhaust and ex-spell it out with little to no smell out the exhaust. There has been quite a few debates on how precise the angle has to be, but many have had good results doing it this way.
Old 02-28-2011, 03:52 PM
aklim's Avatar
aklim aklim is offline
aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.aklim has a very good reputation on FTE.
Quote:
How do you smell it? I can only smell it if I am standing next to the truck while it is idling. Most of the time, I am in the truck driving so I don't smell it too often. Only if I am at a stop for long enough and the wind is blowing just right would I smell it.
As to other people thinking something is wrong with my truck, WGAS? They are not paying for the truck why should their opinion matter?
Tire Recomendations? redbug 1999 - 2003 7.3L Power Stroke Diesel 17 01-05-2016 09:30 PM
Diesel oil in center of engine. redbug 1999 - 2003 7.3L Power Stroke Diesel 6 08-28-2015 05:59 PM
Rear brake line burst.. redbug 1999 - 2003 7.3L Power Stroke Diesel 7 08-21-2014 08:48 PM
Where is the block heater cord? redbug 1999 - 2003 7.3L Power Stroke Diesel 5 02-03-2012 09:45 AM
Is 150k on a 7.3 worn out? redbug Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 13 06-18-2010 01:47 PM
Tags
03, 2011, 60l, 67, 73, boot, cac, clamp, ford, intake, intercooler, kit, leaking, oil, saleen, tube, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
