HELP! No Driver Lowbeam! 07 expy
02-27-2011, 11:50 PM
on
Driver side lowbeam has no power running to it on '07 expy.
I checked and replaced fuses for both passenger and driver lowbeams. The highbeams work for both sides!
And Ideas?
02-28-2011, 09:17 AM
Do you have power to the fuse?
02-28-2011, 11:08 AM
on
Replace the driver side bulb. Likely the low beam filament is burnt.
02-28-2011, 01:07 PM
on
Forgot to mention that I replaced the bulb with 2 others...it was how I determined that there was no power to the low beam...
Someone mentioned that I should check the SBJ (subjunction box?) for power, but I have no idea where that is...
02-28-2011, 01:34 PM
on
Maybe the bulb connector?
03-07-2011, 07:40 AM
on
Had the same problem before when i replaced mine with HIDs.
took my truck to the dealer and they said my headlight switch is the problem.
they replaced it and now it works
04,
2007,
2008,
beam,
driver,
drivers,
expedition,
f150,
f250,
ford,
low,
navigator,
power,
side,
working
