HELP! No Driver Lowbeam! 07 expy - Ford Truck Enthusiasts Forums
2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Old 02-28-2011, 12:50 AM
freerider freerider is offline
freerider is starting off with a positive reputation.
Cool HELP! No Driver Lowbeam! 07 expy
Driver side lowbeam has no power running to it on '07 expy.
I checked and replaced fuses for both passenger and driver lowbeams. The highbeams work for both sides!
And Ideas?
Old 02-28-2011, 10:17 AM
thomabb's Avatar
thomabb thomabb is offline
thomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to allthomabb is a name known to all
Do you have power to the fuse?
Old 02-28-2011, 12:08 PM
kennisonxgs kennisonxgs is offline
kennisonxgs is starting off with a positive reputation.
Replace the driver side bulb. Likely the low beam filament is burnt.
Old 02-28-2011, 02:07 PM
Forgot to mention that I replaced the bulb with 2 others...it was how I determined that there was no power to the low beam...
Someone mentioned that I should check the SBJ (subjunction box?) for power, but I have no idea where that is...
Old 02-28-2011, 02:34 PM
Maybe the bulb connector?
Old 03-07-2011, 08:40 AM
rmr319 rmr319 is offline
rmr319 is starting off with a positive reputation.
Had the same problem before when i replaced mine with HIDs. took my truck to the dealer and they said my headlight switch is the problem. they replaced it and now it works
Tags
04, 2007, 2008, beam, driver, drivers, expedition, f150, f250, ford, low, navigator, power, side, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
