How much weight can a 2001 E-150 haul - Ford Truck Enthusiasts Forums
Old 03-13-2003, 03:35 PM
Rob1eddy Rob1eddy is offline
Rob1eddy is starting off with a positive reputation.
Question How much weight can a 2001 E-150 haul
I have a 2001 E-150 7 pass 4.6 that I have added an eagle lift to. Just how much can I safely haul in this bad boy?
The lift weighs 350. Additionally I need to carry a hot air balloon that is 750 total. How much do I have left?
Old 03-13-2003, 04:38 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Hi Rob1eddy and welcome to FTE
If you click on the "SPECS" button at the right side of the page you will find specs on your van. Hopefully this will help answer your question.
Old 03-13-2003, 07:48 PM
radar_ridr's Avatar
radar_ridr radar_ridr is offline
radar_ridr is starting off with a positive reputation.
the gvwr for the e150 is 7000 lbs. they weigh about 5500 as they sit. that gives you 1500. 1150 after the lift, 400 after the balloon. so basically you and a couple other people and a full tank of gas and you are maxed. keep your tires properly inflated and drive slow and carefully....
Another Crazy Question gmhill33 1987 - 1996 F150 & Larger F-Series Trucks 2 08-15-2015 01:08 PM
2001 E150 Head lamp replacement motoboy 1968-2013 Full Size Vans 1 10-15-2014 07:46 PM
How feasible to lift out a 460 and trans with a lifting plate? sum_weirdo Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 10 06-23-2009 01:30 AM
How much can my 97 F-150 haul and tow? 50flathead 1997 - 2003 F150 3 03-14-2009 10:03 PM
Most Weight ever hauled in your bed. BURNSTOUGHFORD 1997 - 2003 F150 20 06-07-2007 09:20 AM
Tags
1999, 2001, 2003, e150, e250, f150, ford, haul, load, pounds, truck, van, weigh, weight, xl
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
