How remove Wiper Arm on 1978 F250?
Old 02-27-2011, 02:36 PM
smithshaven's Avatar
smithshaven
smithshaven is offline
Anyone know how to remove wiper arms on a 1978 F250... and explain it in a way I can follow? Sure would be much appreciated. Thanks!
Old 02-27-2011, 02:47 PM
79 f350ts's Avatar
79 f350ts
79 f350ts is offline
it's not too bad. lift up on the wiper arm and youll see a small clip next to the shaft. pry this clip back and the arm should lift straight off. sometimes they get stubborn though as they've been on there for 30+ years so be patiant and keep tuggin. hope this helps ya
Old 02-27-2011, 02:59 PM
smithshaven
Thanks 79 f350ts! I'll try it again. That's what was doing. I put a leather work glove in between the cowling to save the paint. I took a 1/4 screwdriver and carefully pushed outward on that clip. The clip moved but the arm wouldn't. It was off when the guy painted it a year ago. He pit it back on so that it's smacking the windshield moulding at the bottom. I know LMC sells a tool for this. Might to order I guess.
Old 02-27-2011, 03:07 PM
79 f350ts's Avatar
79 f350ts
it'll come off without it but frome what i hear the tool makes it easier. mine were a total bear
Old 02-27-2011, 05:44 PM
ranger429's Avatar
ranger429
ranger429 is offline
Take some duct tape and wrap it around the screwdriver to prevent marring the paint. The duct tape also builds the screwdriver up enough to get leverage to get the arm off the shaft. Make sure your prying 180 degrees opposite the spring clip.
mikey1968
10-08-2016 01:58 PM
78f150dent
09-23-2011 12:20 AM
oldblue89
12-25-2009 05:20 PM
walllaw
2004 - 2008 F150
05-23-2006 05:02 PM
razor_jim
Aerostar
01-11-2004 01:23 PM
Quick Reply: How remove Wiper Arm on 1978 F250?
