How remove Wiper Arm on 1978 F250? - Ford Truck Enthusiasts Forums
Old 02-27-2011, 03:36 PM
smithshaven smithshaven is offline
smithshaven is starting off with a positive reputation.
Anyone know how to remove wiper arms on a 1978 F250... and explain it in a way I can follow? Sure would be much appreciated. Thanks!
Old 02-27-2011, 03:47 PM
79 f350ts's Avatar
79 f350ts 79 f350ts is offline
79 f350ts has a good reputation on FTE.79 f350ts has a good reputation on FTE.79 f350ts has a good reputation on FTE.
it's not too bad. lift up on the wiper arm and youll see a small clip next to the shaft. pry this clip back and the arm should lift straight off. sometimes they get stubborn though as they've been on there for 30+ years so be patiant and keep tuggin. hope this helps ya
Old 02-27-2011, 03:59 PM
Thanks 79 f350ts! I'll try it again. That's what was doing. I put a leather work glove in between the cowling to save the paint. I took a 1/4 screwdriver and carefully pushed outward on that clip. The clip moved but the arm wouldn't. It was off when the guy painted it a year ago. He pit it back on so that it's smacking the windshield moulding at the bottom. I know LMC sells a tool for this. Might to order I guess.
Old 02-27-2011, 04:07 PM
79 f350ts's Avatar
it'll come off without it but frome what i hear the tool makes it easier. mine were a total bear
Old 02-27-2011, 06:44 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
Take some duct tape and wrap it around the screwdriver to prevent marring the paint. The duct tape also builds the screwdriver up enough to get leverage to get the arm off the shaft. Make sure your prying 180 degrees opposite the spring clip.
2007 Rear Wiper Arm Removal rhc43 2007 - 2014 Expedition & Navigator 2 12-23-2014 01:28 PM
wiper arms slowrollerzcustoms 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-14-2014 01:46 AM
Wiper arm spring part # Blackwaterforge 1961 - 1966 F-100 & Larger F-Series Trucks 2 04-05-2013 02:25 PM
Wiper linkage replace how do i remove wiper arm GRANT1978 Expedition & Navigator 1 04-14-2011 01:58 PM
How to remove wiper arms on 1989 f150 oldblue89 1987 - 1996 F150 & Larger F-Series Trucks 7 12-25-2009 06:20 PM
Tags
1973, 78, 79, arm, arms, bronco, f100, f250, ford, relpacing, remove, removing, truck, wiper, wipers
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
