Somethins gotta give, need some help guys
on
Update on the truck:
Got the fuel pump relay in and the negative battery cable swapped. i cleaned the grounds on the starter and firewall. Truck now runs and drives but still has a few gremlins.
The voltage stays around 10-12 volts now which doesnt sound right. Also when i fire the truck up, it misses horrible to the point that it would die if i didnt pump the gas. I can get it to not misfire as bad if i pump the gas a little and it gets a little better and i can get it drivin and it goes away after first gear. After that, itle idle just fine but still runs with the "bog" and feeling like im dragging an anchor randomly.
Im at a loss as to whats wrong with her but any imput would be appreciated. id like to keep it on the road for years to come.
thanks guys
thanks guys
on
It runs fine 50% of the time, the other 50% it runs as if its lean on fuel. can u explain what an ECT is? The pigtail on the alternator was replaced 6 months ago along with the alternator. The top plug on the alternator was not however and i beleive that is the voltage regulator?
on
The volts have been goin everywhere, its either too little or too much and the battery light comes on when it spikes depending on whats running (headlights, blower, ect.). Im leanin towards voltage regualtor and im thinkin that if its not lettin the correct volts to charge the battery, its makin the motor run terrible like that and miss upon start up and draining the battery.
If you put in a new alternator recently, the reg. should be OK. But, new parts can go bad. Pull the reg. out and inspect the brushes, they should be sticking out an inch or two?? Not really sure on that measurement, though. Also, it could be a bad relay. Does the voltage fluctuate at idle? If so, you should listen for a clicking solenoid that corresponds to the fluctuations.
on
#29
The temp guage stays on the "o" on (NORMAL) and the heat is just fine comin out of vents. Will i just need to OHM that out?
in a situation like this where you are having trouble pinning down the problem, i would fix what you KNOW is wrong...in this case the voltage. If the voltage is not correct, that can throw off sensors that watch for minute changes in voltage i.e. TPS. I would think the alternator would still be under warrenty, i would change it out and see what happens.
