Phaser Tick Fix without replacing Phasers.
Ok on another forum I been visiting... I found some nice information, and I can now confirm this works myself. That phaser noise that everyone says or claims will end up being the end to your Triton motor if its not fixed, is not actually the phasers. At least for me and everyone else on the forum that has tried this. Its apparently completely related to the VCT sensors. Replacing both got rid of the diesel tick completely. Its gone. So 1100 dollars a side phasers, which they replace the VCT sensors anyway normally, or a VCT sensor that cost 140 bucks and is easy to fix?
Before
YouTube - Before VCT
After
YouTube - VID 20110224 111731
http://www.howstuffinmycarworks.com/VCT_Solenoid.html Click Here for an easy tutorial on how to do it. As I said its best to replace them. I can't confirm that cleaning them would get rid of your tick. You will also wanna buy new seals for them, as the new sensor does not come with the seals. There are two of these fellas remember...
Before
After
VCT Solenoid Very easy to do yourself. Heres a DIY its best to replace the sensor. I can confirm my tick is GONE. Truck does not sound like a diesel. I have never replaced my cam phasers.
The truck is from a guy called "StuckZipper" on another forum. The truck as he stated in as post, is a 04 F150 with 172k miles on it, and has never had the phasers repaired.
My truck is the same thing, 04 F150 with 133k never had phasers replaced. No noise what so ever since replacing these. Do not believe the bs the stealership feeds you, its not the phasers themselves. Its these neat little sensors...
You probably got a bad sensor again.... I'd take them back, and get a new set to make sure. There is a few guys that have had theirs over a few weeks and it hasn't came back. My buddy had his phasers replaced, and got stuck with a huge bill, and they even claimed he had a stuck lifter. When he took the truck in it was running fine other then the annoying tick. He got it back, it still had the tick. he changed those two sensors, hasn't ticking sense. Almost a week on mine, and I even took it out in and went mudding in it, raw hiding the **** outta it. No luck on getting it to tick. It sounds so quiet... it had a bit of a tick but it sounds just like a brand new F150 does, because my neighbor has one. Think thats just the pulley's or something. What causes this issue is supposedly sludge build up on them... So if you haven't changed the oil with a proper motorcraft oil filter, and the 5w20 recommended by Ford, then you may have some sludge build up in your motor, and would explain why once you put the new ones on it still ticked, or you could be one of the select few who actually have a phaser bad, but I am telling you this problem isn't as common as Ford would like us to believe.
Also I spent 94 dollars a piece on these sensors... A lot less then 300, and that was from my dealership here in Kentucky. The seals weren't stupid expensive either. Replaced them as well...
tick
I took my 04 f150 truck in back in dec, I have extended warrenty on it till 2012. My truck now has 65000 miles on it has made this ticking noise since about 30000 miles. When the dealership looked into it and tore it apart they said it was the phazers. after they replaced them, find out it didnt do much, might have quiet it down a lil , but not much. The warrenty I have Is the Mechanic.......NOTE: NEVER, EVER, EVER Purchase a warrenty from them. I googled the company and couldnt believe the hundreds of complaints i red about them. They Are complete A HOLES. They told me that they will not do any more with my truck ticking because they feel its lack of maint. because I didnt have proof of 2 of my oil changes. Which I did on my own, all the rest every 3000 -3300 miles was done at the dealer of garage, and did have proof. But anyways, the warenty comp replaced the phazers. Still have the tick, and it driving me crazy. Sound like a manifold gasket leak, but will not change after warming up. I have been running seafoam in the engine now this last oil change to clean out any sludge build up that seems to be an issue with these motors, and hoping it would maybe help with the tick but no luck. Im gonna look into these sensors a lil more and hope to find out its my fix.
Thanks for the heads up and good luck to the rest of you with the ticking noise.
