New Air ride compressor not turning on - Ford Truck Enthusiasts Forums
1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Old 02-27-2011, 12:51 PM
2000-EB-EXPY-AWD 2000-EB-EXPY-AWD is offline
2000-EB-EXPY-AWD is starting off with a positive reputation.
Just swapped out compressor and the relay that is located in the passenger's side wheel well, and it still wont cycle. I think I checked all fuses, but could have missed one.
The rear is all the way down. Any suggestions on what would cause it not to kick on? Maybe a list of fuses and relay locations to check.
Any and all help is greatly appreciated
Old 03-03-2011, 07:50 AM
Anybody???????
Old 03-03-2011, 10:50 AM
alloro alloro is offline
alloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to beholdalloro is a splendid one to behold
Quote:
I'm not overly knowledgeable with the air suspensions systems, but maybe the hight sensors have a problem and are not sending the signal to inflate.
Old 04-15-2011, 06:27 PM
dsm1mar dsm1mar is offline
dsm1mar is starting off with a positive reputation.
I'm new to this sight and really like what I've seen so far but wanted to ask. I have 1999 Ford Expedition EB 4x4 and at 176,000 the air ride is finally giving me fits. Last week I purchased a pump and installed it but after doing so haven't been able to get it to run. I know the pump works because I read through the post on here last night on how to bypass the pump and it worked. So was thinking it might be the relay especially after pulling them and seeing some corrosion on the posts.
QUESTION: I noticed there are two relays near the compressor and I believe both of them are the same so can I just "swap" them to test if one is bad? Also, is there anything special I need to do after installing a relay? Called Ford and they are $130 but don't want to buy one just to find out it's not the relay causing the problem. Any other ideas as to what is causing this? I have tested all the fuses as well.
Old 04-15-2011, 09:37 PM
Oldtrucknut7077 Oldtrucknut7077 is offline
Oldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputationOldtrucknut7077 has a superb reputation
Welcome to FTE dsm1mar. Try contacting Eddie @ American Air: Parts built for the long haul....not just the warranty period!
He is also a member here on the site.
Old 04-16-2011, 05:43 PM
Moto Mel's Avatar
Moto Mel Moto Mel is offline
Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.Moto Mel has a great reputation on FTE.
If both relays are the finned aluminum types they are most likely the same. The relay for the suspension is behind the driving light on the passenger side. It would be a good idea to know what the other relay is for and to make certain it is good before trying it as a test.
Old 04-16-2011, 07:37 PM
Quote:
The relays are exactly the same because they have the same code. I just swapped them and no luck. I do hear a clicking on the motor of the compressor and can feel the motor "ticking" every once in a while so I know it's trying. Can't remember if I mentioned it but I didn't by pass the relay and the compressor worked. I keep thinking I may have to remove the system completely but now I'm in for $190 because of the "new" compressor.
Old 04-16-2011, 08:01 PM
Moto Mel's Avatar
Where did you buy the compressor?
Old 04-16-2011, 08:16 PM
I purchased it online from Suncore since that was the only site that I could find one that would fit the existing system. Didn't know about this site nor the person suggested before.
Old 04-16-2011, 08:29 PM
pdqford pdqford is offline
pdqford has a good reputation on FTE.pdqford has a good reputation on FTE.
The compressor relay is not in the wheel well. It is on the front support between the front support and the front bumper, at about the same height as the headlight. It is a solid state relay with a finned aluminum heat sink, about 2 inches square - runs $110 + at the Ford dealer. I'm assuming that's the one you swapped out?
@*$%&#!!. Delete this post, I'm getting the two posters confused - my bad!
Old 04-16-2011, 08:31 PM
Moto Mel's Avatar
Did you get a warrantee with the compressor?
I only buy American Air Suspension's products and I don't know of anyone that is unsatisfied with their stuff. It sounds like there will be an internal problem with that compressor. You need to return it for a refund or replacement. If you get a refund ,buy a compressor from Eddie Spinks at American Air.
Old 04-16-2011, 08:34 PM
Yes there is a 1 year warranty for sure.
Old 04-16-2011, 08:40 PM
Thanks for the reply but I am pretty sure I have the correct relay. Mine are in a yellow mount and have 5 prongs on each but the outer case is made of plastic. One set of wires goes to the head light and I believe the other is for the compressor. They were located near the passenger front headlight. I can go back out and pull the code printed on it just to be sure but I can't find anything else that would look like a relay.
Also, I put a tester on the two big wires and was getting juice in both relay mounts....
Old 04-16-2011, 08:44 PM
Could you describe how you were able to "bypass the pump and it worked"?
"after pulling THEM"? I didn't know there were TWO compressor relays. As far as I know there is one solid state relay with a finned aluminum heat sink about 2 inches square - around $110 + at the Ford dealer. I wouldn't call this relay "near the compressor", well maybe it is, but the compressor is accessed from under the hood, but the compressor relay is accessed from underneath the truck, behind the front bumper, at about the height of the headlight, and is mounted to the front support. Is this where you found TWO identical relays?
Old 04-16-2011, 08:53 PM
Pull out your DMM, unplug the compressor relay, and check the harness side of the relay connector to see if there is any voltage available on the light blue/pink stripped wire's pin. This wire should be hot at all times. What reading did you get?
AC compressor wont enngage 96_F250_Deezal 6.0L Power Stroke Diesel 15 09-27-2016 01:27 PM
ac compressor not engaging johnj54 1968-2013 Full Size Vans 4 05-28-2016 11:14 AM
07 Expedition EL A/C Blowing Warm Air martyshel 2007 - 2014 Expedition & Navigator 2 05-07-2015 10:44 PM
99 Xpediton, no power to the ac compressor tmajikman 1997-2006 Expedition & Navigator 6 02-20-2011 10:56 AM
Does the A/C system have a relay or fuse? Where truckmonger1 1999 to 2016 Super Duty 0 04-18-2010 11:05 AM
Tags
1997, 73, air, compreser, compressor, expedition, f250, ford, international, located, relay, ride, shock, test, turning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
