1995 shackle flip questions
I am wanting to do a shackle flip on my 95 f150. I keep reading that this will net about 4.5" of lift in the rear, and is pretty straight forward. The questions I have are, 1. How would I get the front leveled out after flipping the shackles in the rear? (I was thinking 3/4ton springs, but that will only give 2" at most) 2. How would I fix the new pinion angle?
Can't find one for a 1/2 ton in my year. Plus it looks like they are in the $2000 range, which is insane for a lift.. I couldn't justify putting a $2000 lift on a $3000 truck, no matter how hard I try.
EDIT: Found them for my year and model on another site, and MUCH cheaper. The first site I looked at was ungodly expencive.. Now I am seeing 2" lifts for around the $400 mark. I don't like that their "complete kits" are not complete though.. Would still have to get steering stabilizers seperately, along with whatever else they leave out..
As for the brake lines, i think you would be safe w 4" lift
If I would go 4" then I would want one steering stabilizer, just because of the roads I drive every day. I drive a stretch of about 18 miles of the crappiest gravel roads you have ever seen. Some pot holes on this road are deep enough that my running boards hit the ground. With those kinds of bumps I would want one stabilizer on there. If the brake lines would be ok then that would be sweet. Saves me a little bit of $$$
Would I need to get longer brake lines with a 4" lift kit, or would the stock lines reach? Also, would I need swaybar drop brackets? Sorry I'm asking so many questions, I've never lifted anything before.
lift
hey man i have the whole set up u are looking for i have the rough county 4" lift i need to get rid of i have all drop brackets for the axle and radius arms and sway bar i also have the quad shock brackets and drop pitmen arm for the lift. I did a SAS on my 95 f150 is the only reason i dont need the lift no more it all has about 1 year of use and have no problems with the lift !
BRay09
10-03-2015 04:45 PM
Beast_250
03-13-2013 05:20 PM
rustyolred27
03-04-2012 12:42 AM
