Nitto Tires 305 70 18 - Ford Truck Enthusiasts Forums
Old 02-26-2011, 06:08 PM
kidoo kidoo is offline
kidoo is starting off with a positive reputation.
Will they fit on the OEM 18 inch wheel on F350? I have a 2'' leveling in front. How do they look on the truck?
I would like a wider tire than my original Contitrac 275 75 18 any suggestion?
Thanks
Old 02-26-2011, 06:13 PM
Unrealo4's Avatar
Unrealo4 Unrealo4 is offline
Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.Unrealo4 has a very good reputation on FTE.
No clue if they fit the stock rim. But that is the size I'm buying next. I've seen 285/75/18's and mine has 325/60/18's and are too fat and stubby. The 285's were to tall and the tread was too skinny. I'm betting you will love those.
Old 02-26-2011, 06:16 PM
I am looking for the Dura Grapplers, hope they will fit. Where would you buy them?
Old 02-26-2011, 09:12 PM
Benchwrench's Avatar
Benchwrench Benchwrench is offline
Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.Benchwrench has a great reputation on FTE.
I think 305's are too wide for the OEM rim.
you can go with Nitto 295's safely but the 305's should be on 9" rims
They will fit but will be on the inner limit of rim width.
I like to be in the middle of the recommended rim size but to each his own.
Old 02-26-2011, 09:21 PM
I think the oem are 8 inch. Someone says the 305 will wear in the middle with «OME. I wounder how much of a difference? Would it make that much a difference, I am pretty sure they will look much better, do not really want to spend money on new rims.
Old 02-26-2011, 09:25 PM
I checked ont ''compare size'' and the difference on the side wall is 8.1 for the 295 and 8.4 inch on the 305.
Old 02-26-2011, 09:38 PM
Jakebrake's Avatar
Jakebrake Jakebrake is offline
< Samantha...my Co-Pilot
Jakebrake has a good reputation on FTE.Jakebrake has a good reputation on FTE.
Thanks
Stock Conti's are 275/70-18 I believe...at about 33 inches tall. If you get much wider than 285 or 295 you will have a wear problem on the stock rim width. I went with 285/75-18 Toyo's and have been very happy with them They are just under 35 inches tall and will fit with your 2 inch lift. If you go too wide in the snow you may not be happy with the performance of your tire...but they should look nice.
Old 02-26-2011, 09:47 PM
Yes, that is what I worry a bit for wear but I do not intend to go in snow with it. I just wonder how much wear, I carry a truck camper weight about 3500 lbs.
For snow I have some 27 70 18 BF Goodrich AT with about 3000 miles on it
Old 02-27-2011, 09:04 AM
sammy77's Avatar
sammy77 sammy77 is offline
sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.sammy77 has a spectacular reputation.
They will fit. I have had 305/65/18's BFG on my 2005 for a long time now with no issues.
Old 02-27-2011, 09:15 AM
Did you find a difference in MPG with the 305? Wear in the middle?
Old 02-27-2011, 10:43 AM
sammy77's Avatar
MPG's??? Whats that...?lol I really don't pay close attention to it. Technically speaking, yeah mpg's should be worse with a wider heavier tire in general. Not sure if I remember a difference after goin to the 305's. I have good normal wear on my tires. I rotate them evry 10k or so and keep an eye on psi.
Old 02-27-2011, 06:09 PM
Fuel price here is now 4.83 a gallon. It gets pretty scary wiht MPG.
Old 03-30-2011, 07:11 PM
John Luther John Luther is offline
John Luther is starting off with a positive reputation.
I have the 305's Nitto Terra Grapplers on my stock rims with a 2.5" leveling kit. They fit and work fine. No rubbing or scraping on tough terrain. Overall, one of the best tire treads I have had on a truck. Run great in the rain, awesome in the sand, ect... Overall, I am very satisfied, and will buy them again when these wear out, providing I still own this POS 6.0! Oh, and by the way, the truck looks really good, stout, stocky.
Old 03-31-2011, 11:27 AM
Do you find they wear in the middle?
Old 03-31-2011, 12:23 PM
cmcowboy's Avatar
cmcowboy cmcowboy is offline
cmcowboy is gaining momentum as a positive member of FTE.
Not sure if this will help you any, but I run 325/65/18 on stock rims, and I love them. They wear great, no uneven wear at all. But I do have a 4 inch lift though before I put them on.
18" jsduty 2017 Super Duty 2 02-16-2017 08:27 PM
18" tire/rims capacity johndeerefarmer 2017 Super Duty 1 09-13-2016 09:53 AM
Tire size upgrade jsduty 2017 Super Duty 1 09-08-2016 07:41 PM
Stock 18 Rim - Largest tires Adventure Rider Brakes, Steering, Suspension, Tires, & Wheels 7 02-01-2013 01:03 PM
will 325/65/18s fit on standard superduty rim? kkelso 1999 to 2016 Super Duty 5 04-21-2009 09:15 AM
Tags
18, 2857518, 305, 3056518, 30570, 3057018, 385, 70, 94, inch, nation, nitto, powerstroke, sale, ss, tires, toyo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
