Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 03-13-2003, 12:33 PM
yellowrosefarm is starting off with a positive reputation.
Looking for 1" body lift
'78 F250 supercab 4x4 w/460. Does anyone know of a supplier for a 1" bodylift? I want to put a 19" fan in and currently the shroud/ upper rad neck sit about 1" too low. (there's extra room at the bottom) I need to replace the stock body bushings anyway so thought I would go up a little at the same time. I know I could redrill the rad bracket or support but would rather do it with the bushings if possible.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 03-13-2003, 08:46 PM
DPW's Avatar
DPW DPW is offline
DPW is starting off with a positive reputation.
Exclamation Looking for 1" body lift
Don't know where you can buy a 1'' body lift, but you can make your own. I made a 1'' body lift out of aluminum round stock. I had a blacksmith cut 1'' pieces out of 3'' dia. round stock for the cab and radiator support, and 1'' pieces from 2'' stock for the box. Drill the proper size hole in the center of each block. Put the 1'' spacer on the frame, then install your new bushings. Worked for me.
__________________
Remember, (The Best Never Rest)
Jonesy!
  #3 (permalink)
Old 03-14-2003, 06:27 AM
Torque1st's Avatar
Posting Legend
Torque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to beholdTorque1st is a splendid one to behold
Re drill the radiator support!!
Do you know how many hours you are going to spend cussing those body mount bolts and moving parts????
__________________
"Beam me up Scotty. There's no intelligent life down here..."
Eric
Tips & Tricks FAQ for 335 Series Motors
73-79 FAQ & Info
Garage Forum FAQ
For more info use PM.
  #4 (permalink)
Old 03-14-2003, 09:59 AM
I know it is a lot of work to put the new bushings in, and to make matters worse, last fall I had the seats and floor pans out exposing those very bolts. I was pressed for time though, with snow coming and this being the only 4x4 I have to get to work, I didn't do the bushings then. The real problem I'm trying to solve is that the 460 overheats at idle. (even when it was 10 degrees outside) It's not just the gauge either, we're talking boiling water here. As soon as you start moving, it cools right off and in normal driving the needle never moves. When we had the 8 inch sleet storm and I was in 4 low with the pedal to the floor trying to get up the drive, it also overheated after about 15 minutes of that. I have checked the timing and the radiator (3 core), and replaced the 5 blade fan with a 6 blade 17" flex fan. I was just thinking if I could get more flow with the 19 maybe it would help. I'm not sure of the internals although the PO did put a "cam" in when he rebuilt the motor. I've been told by others that it is possible to put the intake or head gaskets in backwards or upside down and cover a cooling passage, but I really don't want to go there if I don't have to.
  #5 (permalink)
Old 03-14-2003, 08:39 PM
Mike W's Avatar
Mike W is starting off with a positive reputation.
If it overheats at 10 degrees, I would look at other things. Maybe get your radiator rodded out, check the water pump.
  #6 (permalink)
Old 03-14-2003, 09:13 PM
Torque1st's Avatar
Posting Legend
A worn out fan clutch can also cause that problem. But you state you have a flex fan. When did you put in the flex fan" Those things don't work worth beans.
When a vehicle is moving the motion of the vehicle thru the air forces air thru the radiator. When you slow down in traffic a fan is required. This would explain your problems.
__________________
Eric
73-79 FAQ & Info
Garage Forum FAQ
  #7 (permalink)
Old 03-14-2003, 09:29 PM
fordenator is starting off with a positive reputation.
hey for a lift try a hockey puck they're around an inch. i've used them for replacing my rad support monts and that was about 6 years ago.
  #8 (permalink)
Old 03-18-2003, 03:19 PM
Thanks for the suggestions. I know I need more flow, that's why I'm trying to put the 19" fan in there. I think it will work, if I can get the shroud centered.
  #9 (permalink)
Old 03-23-2003, 07:42 PM
I redrilled the radiator and support 1" higher and cut off the low hanging part of the shroud under the top radiator hose. I riveted a piece of 16 ga galvanized metal in place of the now missing piece. Once everything was bolted up, the 19" big blade fan was centered up nicely with about an inch all around. I ran it today with the temp here in the 70's and let it idle while I was waiting for the people at Lowes to help me load a new washing machine. ( a long time) The needle never got above the "N" and I could hear the new fan clutch cutting in and out. So I think that solved the problem. It just wasn't getting enough air flow through the radiator at idle with the 5 blade stock 17" or the new 6 blade 17" flex fan. While I was working on it I found the lower radiator hose had 2 rubbed places on it where it had been resting on the front cross member so I replaced that too. Now to see if I can get the A/C going.
  #10 (permalink)
Old 03-23-2003, 08:55 PM
Torque1st's Avatar
Posting Legend
Usually when you have problems with heat at idle or other slow speed maneuvers with no problems at speeds over 40, the problem is the engine fan. Either a bad fan clutch, a missing shroud (or the wrong size), or an aftermarket flex fan, is the problem. We see this all the time here.
The 17" five blade stock fan should have been more than adequate to cool your engine at idle unless there is another problem like a faulty auto tranny, or bad ignition timing etc.
Sounds like you did a good job on the shroud.
__________________
Eric
73-79 FAQ & Info
Garage Forum FAQ
  #11 (permalink)
Old 03-23-2003, 10:27 PM
fordguy76's Avatar
fordguy76 is starting off with a positive reputation.
you can find a body lift in any 4wd magazine. performance accessories has them. thats the company performance accessories. just search around for it. good luck
__________________
seth cooper
78 F-150 4x4 ranger xlt
4 inch Skyjacker lift
71 429 4bbl C6 auto
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
