2000 Excursion HID lights - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 02-26-2011, 07:03 PM
motopsyko32's Avatar
motopsyko32 motopsyko32 is offline
motopsyko32 is starting off with a positive reputation.
I bought my 2000 Ex a while back with HID lights. I noticed the lights were pointing too low... I adjusted them the best I could but they still seem low. Is there a poor mans way of adjust the lights correctly?
Old 02-26-2011, 07:36 PM
RACERX7775's Avatar
RACERX7775 RACERX7775 is offline
PROFESSIONAL KNOW-IT-ALL
RACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to beholdRACERX7775 is a splendid one to behold
are they aimed low or do they just seem to look low? follow me? most hid kits (cheap junk) throw light in all directions and they have to be aimed pretty low as to not blind oncoming cars. those "kits" arent really designed to work with a halogen reflector headlight housing. many will disagree with my statement, and they say they work great for them, but,..... Thats why I made my own "real, projector" hid lights from a range rover.
Old 02-26-2011, 07:55 PM
az2ny2008's Avatar
az2ny2008 az2ny2008 is offline
az2ny2008 is starting off with a positive reputation.
how did you make urs from a range rover i agree with you hids are only to work at there best when they are in projectors cuz u have to cut the light.
They sell a projector kit on ebay but i heard the hid gets too hot and is close and melts the lense.
Old 02-26-2011, 08:06 PM
RACERX7775's Avatar
sorry, old pic. hid lights usually dont put out the heat but anything is possible with the ebay kits. as for mine, i opened the factory housing, and put a set of projectors in, aimed, and resealed the housings. the ballast is in a sealed box near the headlights.
Old 02-26-2011, 11:04 PM
bought the truuck with them but they are not projectors. I would feel better if the lights at least went all over the place, but the only light up the road in front of the car about 6 to 8 feet and they dont light up the overhead signs on the highway or the signs on the side of the roads
Old 02-26-2011, 11:29 PM
CanadianSmokie's Avatar
CanadianSmokie CanadianSmokie is offline
CanadianSmokie is gaining momentum as a positive member of FTE.CanadianSmokie is gaining momentum as a positive member of FTE.
Go to a shop that has the proper setup to aim lights... my shop did mine in about 15 minutes...cost me less than $20 and I know they are properly aimed.
Old 02-27-2011, 09:59 AM
if its that cheap I will go to a shop. i didnt think it would be that cheap
Aftermarket Dual projecter HID housings for 99 F150 BEEFKING69 1997 - 2003 F150 5 04-07-2015 08:55 PM
HID Problem Slapshottr Excursion - King of SUVs 4 12-21-2014 03:13 AM
7.3 HID Kit chrisbrady498 1999 - 2003 7.3L Power Stroke Diesel 12 06-13-2014 07:04 PM
Hid upgrade in stock housing fishbones182 2009 - 2014 F150 15 12-25-2013 11:11 AM
HID lights tbaker00 6.7L Power Stroke Diesel 114 03-18-2012 05:52 PM
Tags
00, 2000, 2005, conversion, excursion, ford, forum, headlight, headlights, hid, kit, kits, light, lights, projector, propane, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
