engine missing under acceleration - Ford Truck Enthusiasts Forums
Old 02-26-2011, 06:54 PM
tored1971 tored1971 is offline
tored1971 is starting off with a positive reputation.
Angry engine missing under acceleration
I have a 2005 FX4 with a 5.4L.
I have noticed in the past 3 months that when I mash the go pedal hard the engine misses and there is a popping sound.
My gas mileage has gone down 2-3 MPG.
Has anyone experienced this problem?
I can't afford to take the truck to a dealer to diagnose and hope I can fix it myself.
ANY help will be GREATLY appreciated!
Thanks, Phil
Old 02-26-2011, 08:23 PM
Wilber15 Wilber15 is offline
Wilber15 is starting off with a positive reputation.
Get it scanned for codes first to find out what cylinder is missing... Problably has a coil going bad.
Old 02-27-2011, 11:45 AM
shawn_N's Avatar
shawn_N shawn_N is offline
shawn_N is new and has a neutral reputation at this point.
how many miles? and have you replaced your plugs? it might be time.
Old 02-27-2011, 01:33 PM
flash69 flash69 is offline
flash69 is starting off with a positive reputation.
I have an 06 f-150 doing the same thing.
5.4 - 53,000 miles - Code for #8 cylinder
I thought it was the COP and replaced it however the problem is still going on.
Old 02-27-2011, 02:00 PM
shawn_N's Avatar
plug or the injector.
Old 02-27-2011, 03:11 PM
The truck has about 60,000 miles on it.
The odd thing is that it doesn't do it every time, just once in a while.
Thanks for the help guys.
Keep the info coming, Phil
Old 02-27-2011, 03:23 PM
shawn_N's Avatar
are you throwing a cell when it does it? if so get the code read. you have 1 or 3 choices here.
60K....you might have a bad COP, you might have a bad plug, or you might have a faulty injector.
try to get it to do it and throw a code. moneys tight....been there done that. if it throws a code see which cylinder it is giving you the code. then switch COP's with another cylinder and see if the code will follow you or if it stays on the cylinder. if it follows you and moves to another cylinder then replace the COP. if it stays on the same cylinder that you originally got the code from, you either have a bad plug, or a bad injector. might be cheaper to replace the 1 plug until you come across some money in order to do them all. or do both. a Motorcraft plug is 8 bucks, and an injector ( cant remember but guessing its about 50 or so bucks from orielys )
hope this helps.
Old 02-27-2011, 03:25 PM
shawn_N's Avatar
i had the same problem you have. changed out the plugs, replaced 1 of the COP's and she gets up and goes now.
Old 02-27-2011, 04:45 PM
Thank You Shawn.
I know someone here has replaced the plugs on a 5.4.
I've read the horror stories about breaking the plug off in the cylinder head.
How much of a pain in the butt is it to do it yourself?
Phil
Old 02-27-2011, 04:49 PM
shawn_N's Avatar
with the lisle tool, not bad at all. just time consuming. i done mine.
Old 02-27-2011, 06:40 PM
alfack alfack is offline
alfack is starting off with a positive reputation.
Mine was doing the same thing and idling rough when cold.
After replacing the plugs, fuel filter and o2 sensors, the thing is running like new.
The plugs on mine were a royal PITA. Broke 5 out of 8, but that Lisle tool worked well. Make sure you insert the pusher pin (the instructions don't mention it) and you need a deep 15/16" socket for the outer nut on the tool.
truck misses and dies when it rains...... varminthunter243 1999 - 2003 7.3L Power Stroke Diesel 19 12-04-2014 07:13 PM
F250 engine missing riverratba 1999 to 2016 Super Duty 18 12-22-2013 01:03 AM
5.4 triton 3 valve. Rough idle?? ceven1 2004 - 2008 F150 2 05-17-2013 10:23 PM
quick hesitation that almost feels like a miss Garryche Explorer, Sport Trac, Mountaineer & Aviator 5 05-03-2011 11:22 PM
97 Ford Expedition 5.4 engine miss 97EBexpedition 1997-2006 Expedition & Navigator 6 02-19-2010 09:20 PM
Tags
06, 2003, 2004, 42, 54l, 73, 85, acceleration, diesel, engine, f150, f350, ford, miss, misses, missing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
