Inertia switch surprisingly sensitive
my truck got me stranded right in front of the local Autozone store last weekend lol. At first the truck would barely start and sort of blubber at below 500 rpms, gas pedal did nothing. This was just normal driving on surface streets too, I went to 3 other places too before I got stuck. Anyway I figured gee, maybe it's time to replace the fuel filter, so I did that right there in the parking lot, and after that it was 100% no start at all. Whatever fuel pressure was in the line was now gone and the pump is not working. I haven't tried the inertia switch yet nor looked at the replay behind the radio... I'm hoping its one of these 2 things and not the pump itself. My truck only has 64k miles on it hard to believe the pump would go out that soon?
It was a few years ago and not my truck, but I got stranded on a boat ramp. I backed the trailer into the water, my (former) father-in-law drove the boat onto the trailer, I secured the bow strap, winched the boat up tight, hopped into the truck, put it in drive and fed it some throttle....it sputtered and died.
We ended up getting towed off of the ramp by a 1 Ton Chev DRW (embarrassing). 90 minutes later our troubleshooting led us to the inertia switch.
That was a "WELL DUH" moment.
If your tank is mostly empty it would probably be easier to just drop the tank. I did the one on my Excursion in about two hours.
I could not anything that would require a manual reset like we used to have in the fleet Crown Victoria's and Explorers I used to drive, but I did find this ..........
From page 321 of my owners manual 2012 F350
FUEL PUMP SHUT-OFF
In the event of a moderate to severe collision, this vehicle is equipped
with a fuel pump shut-off feature that stops the flow of fuel to the
engine. Not every impact will cause a shut-off.
Should your vehicle shut off after a collision due to this feature, you may
restart your vehicle by doing the following:
1. Turn the ignition switch to the off position and wait 10 seconds.
2. Turn the ignition switch to the on position.
3. Repeat steps 1 and 2 to re-enable fuel pump.
Note: For vehicles equipped with a diesel engine, see the Diesel
supplement for additional Fuel Pump Shut-off reset instructions.
FUEL PUMP SHUT-OFF
Never ever read that in the owner's manual or any of the owner's manuals on my farm tractors either.
Last edited by schrod; 02-17-2014 at 11:42 AM. Reason: omitted smartass remark from text.
VannerDude
02-22-2015 01:54 PM
emboyd
08-27-2003 08:53 AM
