Expected life of 7.3 vs 2011 6.7?? - Ford Truck Enthusiasts Forums
Old 02-26-2011, 11:02 AM
bigtexan99 bigtexan99 is offline
bigtexan99 is gaining momentum as a positive member of FTE.bigtexan99 is gaining momentum as a positive member of FTE.
I was watching this slideshow on the Ford 6.7 diesel and the engineers were saying that they tested the engine to 250,000 miles.
Diesel Forum Presentation
Does anyone know what International tested the 7.3 to? I know there are alot on the road with 400k+ miles. Was the 7.3 a freak of nature or was it designed that way?
Old 02-26-2011, 11:20 AM
ty8573's Avatar
ty8573 ty8573 is offline
ty8573 is starting off with a positive reputation.
I will vote freak of nature.hahaha
Old 02-26-2011, 11:21 AM
Shake-N-Bake's Avatar
Shake-N-Bake Shake-N-Bake is offline
Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.Shake-N-Bake has a spectacular reputation.
When we bought our 7.3 work trucks we scheduled them for engine overhaul at 300k miles because that was what the dealer said the life expectancy was.
Since then we have had 2 trucks run over 600k until we traded them in. At the time they were still running fine. For the remainder of our fleet, we adjusted the overhaul marker to 500k and will see what they look like when the time comes.
Not sure what the 6.7 published life is...I think it's still at 300k according to Ford. The Cummins 6.7 is 500k.
Old 02-26-2011, 11:23 AM
miller_feed's Avatar
miller_feed miller_feed is offline
Hook it, I'll pull it.
miller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputationmiller_feed has a superb reputation
The freak of nature is the EPA.
Old 02-26-2011, 11:36 AM
Kwikkordead's Avatar
Kwikkordead Kwikkordead is offline
Kwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputationKwikkordead has a superb reputation
I think rear axle ratio has something to do with engine life.
My F550 with 4.88 is on it's second engine, replaced at 105,000 miles.
It didn't blow up, but developed a knock that was audible on deceloration.
I didn't want to be stranded somewhere out on vacation with the 5th wheel so I elected to replace it.
Bfife's F550 is on it's second engine too. He bought it that way from the government and it was replaced somewhere in the 30,000 mile range according to the report when he bought it.
Old 02-26-2011, 01:48 PM
camodown's Avatar
camodown camodown is offline
camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.camodown has a great reputation on FTE.
Per International's literature, the T444E has a B10 life of 200,000 miles and a B50 life of 350,000 miles, which is the same as the older 5.9 Cummins B series. With Ford's programming, I don't know, but can reason those aren't too far off from what I have seen.
Note: Cummins does not publish B10 for their ISB 5.9 directly, only B50
Last edited by camodown; 02-26-2011 at 07:36 PM. Reason: Confused my numbers B20/b10
Old 02-26-2011, 03:10 PM
PaulDH PaulDH is offline
PaulDH is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by camodown View Post
Per International's literature, the T444E has a B20 life of 250,000 miles and a B50 life of 500,000 miles, .
What's the definition of B20 and B50?
Old 02-26-2011, 03:15 PM
Quick444's Avatar
Quick444 Quick444 is offline
Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.
Quote:
I think it is described as the "half life" of the engines. If I am correct, I think it means that 20% of the engines will require a major overhaul at 250,000 miles and 50% of them will need a major overhaul by 500,000 miles.
We will see what the pros think but I thought I read this somewhere before.
Old 02-26-2011, 07:34 PM
camodown's Avatar
The definition of Bx life as per International is 'requiring major repair which requires head removal or oil pan removal.'
Old 02-26-2011, 07:47 PM
Does B20 mean that International projected that 20% of their T444Es were likely to require major repair by 250,000 miles? And does B50 mean that 50% were projected to require a major repair by 500,000 miles?
Old 02-26-2011, 08:45 PM
camodown's Avatar
Yes, major as in one or both heads off, or oil pan coming off. I misquoted the B50 as 500,000 mi whereas it really is 350,000. This is ONLY an estimate though!
Old 02-27-2011, 12:14 AM
4wydnr 4wydnr is offline
4wydnr is starting off with a positive reputation.
If the oil pan coming off is a marker for the B10 or50, then the mileage would have to he way lower than 300k. Simply due to oil pan rust.
My 7.3 made it just shy of 170k. It's a good thing I have a cummins with 300k to get me around, or I'd be pedaling a huffy.
Old 02-27-2011, 12:24 AM
snakedoc's Avatar
snakedoc snakedoc is offline
Ford With Out Tax Money
snakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to beholdsnakedoc is a splendid one to behold
Quote:
x2
i think the reason it last is it is simple KISS. all the new ones have 100 sensors more to go bad.
Old 02-27-2011, 12:29 AM
dn29626's Avatar
dn29626 dn29626 is offline
dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.dn29626 has a great reputation on FTE.
I would like clarification too.
Old 02-27-2011, 12:33 AM
ricksw ricksw is offline
ricksw is starting off with a positive reputation.
Whats for say ford the 6.0L for life
2012 F250 6.7L Diesel - help cowboy1972 6.7L Power Stroke Diesel 16 01-03-2017 10:59 PM
Diesel engine sound.? srkr 2017 Super Duty 6 12-02-2016 09:49 PM
2015 F250 6.7L madd91 6.7L Power Stroke Diesel 10 06-11-2016 11:28 PM
7.3L to 6.7L question. Tugly 6.7L Power Stroke Diesel 57 08-06-2015 09:23 AM
Ford Engineers say the Design Life of the PSD..... JumpinJoe 1999 - 2003 7.3L Power Stroke Diesel 42 10-04-2009 08:21 PM
Tags
2001, 64, 67, 67l, 73, b10, b50, diesel, engine, expectancy, expected, ford, life, powerstroke, vs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
