Another 4x4 conversion
Old 02-26-2011, 02:20 AM
Henryj1010's Avatar
Henryj1010
Henryj1010 is offline
Question Another 4x4 conversion
I've got a 1959 Ford Panel Truck, and I want to convert it into 4x4 and power it with a 4.6L modular and c6. hope I can convert it to 4x4 without a frame swap, was wondering which and what year dana front axle would work best. I was thinking 44 with leaf springs was wondering if a 61 thru 65 front end would work well? Also as far as leaf springs will the existing 2wd type leafs be enough to support a 44 axle if not would 61-65 4x4 leafs that go with the 61-65 dana bolt up to a 59 f series panel.
thanks any help is appretiated
Old 02-26-2011, 06:18 AM
kenjh's Avatar
kenjh
kenjh is offline
didn't know you could bolt a C-6 to a mod motor...I have a 79' bronco with a 428 fe,,and the d-44 is working fine,,,as long as I don't play to hard..what are you going to use for a transfer case?? It can be done it just takes lot's of cash and a little time or lots'a time and a little cash...will the mod even fit in there??
Old 02-26-2011, 07:11 AM
havi's Avatar
havi
havi is offline
I'll have the Roast Duck
Your panel, in theory, should have the same components of a '59 F100 4x4. So either a front suspension swap from one, or use the entire frame from one, would get you a factory 4x4 set up. Then it's a matter of making the engine and transmission/tcase fit. There was 1 year where the 4.6L shared the SBF bell pattern, then you could use a SBF C6 4x4 tranny and tcase. There would likely be some ample time in locating all of these parts, though. Good luck!
Old 02-26-2011, 10:18 AM
kenjh's Avatar
kenjh
kenjh is offline
I really enjoy all the gearheads here so much to learn so little time
Old 02-26-2011, 05:36 PM
fordman75's Avatar
fordman75
fordman75 is offline
I haven't seen anybody that sells an adapter to go from the mod motor to a C6. I have seen a Bellhousing to use a C4 on a mod motor. These guys sell it ATI Racing Transmissions - Ford C4 Transmissions . But it's over $500 just for the bellhousing!
1964FORDTUF
07-15-2015 06:15 AM
brian42
05-13-2015 11:15 PM
NoDough66
08-18-2013 07:23 PM
jason10henry
05-28-2012 04:08 AM
Quick Reply: Another 4x4 conversion
