1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
unibody 4x4 ??
Old 08-07-2011, 12:43 PM
ajcal225's Avatar
ajcal225
ajcal225 is offline
I'm pretty sure there isn't any mystery these days. F11 = 4x, F10 = 2x. There are a lot of conversions out there.
I'm comfortable these days in the fact mine has to be a conversion. It's still the sexiest damn 4x4 in town (and there are a LOT in town).
Old 08-10-2011, 02:24 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Originally Posted by ajcal225
The genlteman I bought my '62 uni 4x4 from in 1991 claimed to have been the second owner. He says he bought it from the US Dept of Forestry in the early 80's, and that they had special ordered them from the dealer that way (dealer conversion). It may be a M-H conversion, but did not have any instruction plates. It is an F10 vin.
I can't say that any of that is true or not, but it seemed plausable enough at the time - except that there is no hint of the forestry service green paint *anywhere."
F10 = F100 2WD
Look on the Warranty Plate for the COLOR code, post what it is. Also look on this plate for the DSO code, post that also.
IF the truck was ordered special by the US Gov't, and was painted a non standard color, there will be no COLOR code.
IF the truck was a 'Domestic Special Order," there will be a 4 numbered DSO code.
IF not a special order, there will be no DSO code of any kind, just a blank space.
1961/62 F Series trucks do not have a DSO code unless a special order. 1963 and later all have a DSO code which is two numbers if an RPO (Regular Production Order) or 6 numbers if a special order.
btw: Fullerton is just 'over the hill' from Hacienda Heights, so I could swing on by and take a look-see.
Old 07-03-2012, 11:19 AM
62Uni4WD's Avatar
62Uni4WD
62Uni4WD is offline
Thanks for the info guys. It adds to my confusion. I have a 62 unibody that I've owned for 26 years. I bought it in Idaho in 1986. It is a 4 wd and the vin is an F11. From the thread, unibodies did not come from Ford as a 4 wd but if they did the vin would be F11/F26. Help!
Old 07-03-2012, 11:21 AM
ajcal225's Avatar
ajcal225
ajcal225 is offline
the word of the day is 'bodyswap'.
Old 07-03-2012, 11:24 AM
62Uni4WD's Avatar
62Uni4WD
62Uni4WD is offline
The VIN I used is on the door of the glove box. I assume it is for the body?
Old 07-03-2012, 11:25 AM
ajcal225's Avatar
ajcal225
ajcal225 is offline
not hard to swap the glove box door over when you swap bodys, to keep your vin correct.
Old 07-03-2012, 11:27 AM
62Uni4WD's Avatar
62Uni4WD
62Uni4WD is offline
Interesting. Thanks ajcal225
Old 07-03-2012, 11:28 AM
ajcal225's Avatar
ajcal225
ajcal225 is offline
I'm just guessing mind you, but that would be my guess. Someone had a 4x4 and wanted a unibody.
In my case, someone had a unibody and wanted a 4x4. I tracked it down to a dealer in Ohio that did the conversion.
Old 07-03-2012, 11:33 AM
62Uni4WD's Avatar
62Uni4WD
62Uni4WD is offline
Just as an FYI, here is my VIN. Any info is appreciated. 9F110CR290268
Old 07-04-2012, 12:40 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
Whats with the 9 in front of the vin? Are you sure you read that vin correctly?
Old 07-04-2012, 10:00 AM
62Uni4WD's Avatar
62Uni4WD
62Uni4WD is offline
That was on my insurance card. I'll check the truck when I get home from work. Thanks
Old 07-04-2012, 12:32 PM
62Uni4WD's Avatar
62Uni4WD
62Uni4WD is offline
Thanks. The number is F10 and not 9F11. I don't know how that was missed.
  #28
Old 07-05-2012, 11:48 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
An f10 indicates a 2wd truck an f11 a 4wd. So it looks like your insurance card is just indicating a 4wd truck where your truck vin appears to show it to have been converted to 4wd.
  #29
Old 07-05-2012, 11:49 AM
62Uni4WD's Avatar
62Uni4WD
62Uni4WD is offline
Yeah that's what it looks like. Anyone know where I can find the VIN on the frame? Thanks in advance
  #30
Old 07-06-2012, 01:03 AM
Buzz44's Avatar
Buzz44
Buzz44 is offline
It should be in two places on the passanger side frame rail. Possibly between the core support and the front axle stamped on top of the frame rail. Next would be toward the front of the cab or under the cab. On my 65 4wd truck it was between the core support and the shock tower mounting bracket. The number under the cab is stamped on top of the rail too. Be prepared to scrape and scratch to find that number probably coated in rust and who knows what all. Good luck.
Quick Reply: unibody 4x4 ??
