352 swap to 390
The 68 360 already has a 390 bore block, not sure why you would build the 352 instead.
The local either doesn't want the job or has priced you something way out on a limb.
Get another opinion/price. Keep looking.
BTW, Where are you located, this is a huge site with lots of readers, maybe a local can help point you in the right direction.
John
John
Believe the balancer/damper and pulley changed in 68, if not mistaken, should be able to use the 66 balance and pulley on the 68 but can't use the 66 damper w/ later pulley, the bolt pattern is different. In meantime, might want to keep an eye out for 2-3 sheave damper pulley in event later decide to go with p/s upgrade.
Everything that bolted on to your 352 will bolt to the rebuild 390. Flywheel to balancer, heads to oil pan.
As to the heads being taller in the intake dont worry about this unless you are building a screamer. This can be cured with an aftermarket intake. There millions of rebuilds out there with mis matched heads.
Garbz
Garbz
Garbz
Garbz
