EOT sensor
Old 02-25-2011, 06:34 PM
ttttmaxx's Avatar
ttttmaxx
ttttmaxx is offline
EOT sensor
Do you have to drain the Hpop reservoir to change the EOT sensor? thanks
Old 02-25-2011, 06:37 PM
big poppa's Avatar
big poppa
big poppa is offline
I believe the sensor is right there on the top of the HPOP...No need to drain if it is..
Old 02-25-2011, 07:20 PM
ttttmaxx's Avatar
ttttmaxx
ttttmaxx is offline
I think the one on top is a pressure sensor?? The one Im speaking of is at the bottom backside drivers side? I need to replace and think I read you have to drain reservoir. Maxx
Old 02-25-2011, 07:29 PM
F350-6's Avatar
F350-6
F350-6 is offline
You don't have to drain it. Some oil may come out, but if you stuff a rag under the sensor you should be able to catch it. If oil does drain out, it's a good idea to top the reservoir back off after you install the new sensor.
Old 02-25-2011, 07:32 PM
big poppa's Avatar
big poppa
You could be right, don't have my sensor chart handy but Chris got you covered..
Old 02-25-2011, 07:33 PM
ttttmaxx's Avatar
ttttmaxx
ttttmaxx is offline
thanks! I wasn't sure if oil would just pour out once i pulled the sensor...MAXX
Old 02-25-2011, 07:36 PM
timmyboy76's Avatar
timmyboy76
timmyboy76 is offline
Cant find the "link", but i did downloadthe pic, but cant get it posted...anyway, the EOT is on back/driver side, at top, the EOP is on top of hpop, and the IPR is down bottom driver side on back of hpop...guess i cant post attachments..argh
Old 02-25-2011, 08:00 PM
F350-6's Avatar
F350-6
F350-6 is offline
Create a gallery here and you can upload pictures to it. From there you can insert the pictures in a thread.
andy's2000
26
11-06-2016 08:42 PM
Excurvelle
07-26-2015 10:13 AM
bookem15
06-02-2015 10:04 PM
andy's2000
20
03-15-2015 05:56 PM
rebelchevy02
41
01-26-2009 07:51 PM
Quick Reply: EOT sensor
