dana 60 gears - Ford Truck Enthusiasts Forums
dana 60 gears
Old 02-25-2011, 01:11 PM
williamgrogan's Avatar
williamgrogan williamgrogan is offline
williamgrogan is starting off with a positive reputation.
dana 60 gears
i use my truck daily 460 big block we all know doesnt do great on milage right now im getting 11mpg im going to change the rear end gears the problem i have is; i was wanting to know could a set of gears out of a dana 60 non floating axel work in a dana 60 full floating axel
Old 02-25-2011, 01:54 PM
glovemeister glovemeister is offline
glovemeister is gaining momentum as a positive member of FTE.glovemeister is gaining momentum as a positive member of FTE.
I think they would, however I would strongly advise you you get something in the 3.73 range and then get an overdrive unit.
Old 02-25-2011, 02:18 PM
i would get a gear vendors overdrive but there almost 3 grand for one is there any overdrive transmissions that would fit my truck?
Old 02-25-2011, 03:35 PM
cadunkle's Avatar
cadunkle cadunkle is offline
cadunkle is gaining momentum as a positive member of FTE.
Cheap swap to overdrive would be a ZF5. Bolt in swap.
Better swap would be an NV4500. That gets expensive but the trans is a lot stronger. Still cheaper than a gearvendors though.
Old 02-25-2011, 04:12 PM
i would like to stick with an auto to keep the truck somewhat stock but a manual would be nice now is the bolt patteren on a 7.3 the same as a 460?
Old 02-25-2011, 04:21 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Quote:
No, the diesel uses a different bellhousing bolt pattern.
There is an option for auto trans with OD. The E4OD was used behind 460's in later model trucks. Only drawback, they require a controller to make them work, as they are electronically controlled.
Old 02-25-2011, 06:30 PM
IDIDieselJohn's Avatar
IDIDieselJohn IDIDieselJohn is offline
IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.IDIDieselJohn has a great reputation on FTE.
Non floating axle with a 460? That's a first. Usually all 460's had full floaters.
Old 02-25-2011, 06:41 PM
I'm thinking he has a Dana 60 NF, and wants to swap the gears into his Dana 50-60 Full Float rear in his 460 truck?
Old 02-26-2011, 01:35 PM
would the five speed off of a inline 6 work on my 460 this is my first 460 i have always had inline six trucks
Old 02-26-2011, 01:39 PM
No, you'll need a 5 speed out of a 460 to fit a 460. No other engine had the same bell housing that the 460 has. (no other big block had a 5 speed, so only 460 5 speed will fit)
dana 60 one ton wheel hubs Sean Balboni 1973 - 1979 F-100 & Larger F-Series Trucks 23 04-09-2013 09:02 PM
what axels? Farmall05 1987 - 1996 F150 & Larger F-Series Trucks 4 02-21-2012 08:18 AM
diff swap extangtruck Clutch, Transmission, Differential, Axle & Transfer Case 2 01-09-2007 06:48 PM
axel code help Nedcampion 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 03-18-2006 02:55 PM
Rebuilt DANA 44??? javi2001 Clutch, Transmission, Differential, Axle & Transfer Case 9 01-19-2004 02:22 PM
Tags
1977, 1990, 1996, 2010, 460, 60, automatic, dana, end, f150, fit, ford, gears, motorhome, od, rear, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
