Can new exhaust increase HP & torque - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 02-25-2011, 10:01 AM
mcons1 mcons1 is offline
mcons1 is starting off with a positive reputation.
I just traded in my 2007 F150 for a 2011 F350 King Ranch with a 6.2L V8 Gas. I was looking at the specs and it indicates that my peak HP is 385 and peak torque is 405. Is there an aftermarket exhaust sytem I can install that will increase these numbers without voiding my warranty? I will be towing an 8000# camper this summer.
Old 02-25-2011, 10:27 AM
acf6's Avatar
acf6 acf6 is offline
acf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputationacf6 has a superb reputation
Thats a pretty good amount of power for stock.. but im sure someone will have an answer for you
Old 02-25-2011, 11:15 AM
DAVE67FD's Avatar
DAVE67FD DAVE67FD is offline
DAVE67FD is gaining momentum as a positive member of FTE.
Im sure the new 6.2 flows probably as good as it can. On the older trucks swapping out the Y pipe for a performance one helped but was not a big HP contributor.
Regardless i don't think theres much of anything yet available for your 2011. Any performance full dual or cat back system is pretty much just going to make it sound nicer or more anoying (depending on how you view loud/er exhaust systems). It will do very little if anything at all in the MPG area as well but tends to make it worse because your more likely to put your foot in it more cause you like how it sounds. Again you won't find any direct fit aftermarket packages that fit the 2011. You would have to buy your mufflers etc.. and have a shop fab it all up for you.
Depending on your dealership, some can be **** and use every excuse to not cover your items so call them first before and if you do any mods. If you need more power you could try a tuner but i would get a few miles on her first. In addition not sure how many outfitts have added the 6.2l to their list. I know 5-star tunning and SCT is the favs for the 5.4l.
Old 02-25-2011, 11:58 AM
dkf's Avatar
dkf dkf is online now
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
There are some catback exhaust systems on the market for the 6.2l in the SD currently. You will more than likely pick up a very small increase in performance and will pick up some extra sound. With a pre engineered catback your warrenty should be fine however you could ask your dealer. Looks like Gibson, Banks and maybe Corsa currently makes a system for the 6.2l SD. Take a look down in the 6.2l section for more info and pics.
6.2L V8 - Ford Truck Enthusiasts Forums
http://www.ford-trucks.com/forums/98...2-exhaust.html
Banks Power | 99-11 Ford - 6.8L V10; 6.2L V8>>Monster® Exhaust
http://www.summitracing.com/parts/GIB-319657/
Old 02-25-2011, 01:32 PM
REXHOUND REXHOUND is offline
REXHOUND is starting off with a positive reputation.
not on that engine, sounds all ya get
C6 Shifting at 4000 RPM. danlee Clutch, Transmission, Differential, Axle & Transfer Case 11 02-02-2013 06:40 PM
Torque/horsepower metrics fully measure how quickly an engine can rev? ChrisFromTheForest 5.0L Coyote 5 03-14-2011 11:16 PM
Power,Torque, Power Question LIKENIT Modular V10 (6.8l) 39 08-14-2007 09:54 PM
Towing With A Gasser jschira Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing 31 11-26-2006 07:38 PM
Anyone use a ford racing cam that.... jwtaylor Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 10 08-31-2003 04:11 PM
Tags
62, banks, corsa, duty, exhaust, f250, ford, gibson, horse, hp, increace, increase, increases, power, putting, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
