Crank no start F-350
Old 02-24-2011, 10:46 PM
mercedes4oil's Avatar
mercedes4oil
mercedes4oil is offline
Truck: 1996 Ford F-350 7.3 Diesel 190K on the clock, new Glow Plugs 4 weeks ago.
I have read many post from this board while troubleshooting my truck. Thanks for the help so far. However, I was driving home with a load of mulch and out of no where the truck started loosing power at a hill, by the top of the hill I had it to the floor and was only running about 15 mph. I shifted into neutral and tried revving it up, but it just stopped running. I coasted into a parking lot and called a buddy he brought a truck & trailer and new CPS Sensor (Ford Dealer Part). I changed the CPS in the parking lot, but still no start. We towed it home and now it sits in the garage.
Day 2:
Had batteries on charge several hours. First battery brand new, second couple years old but tested fine. Truck spins over strong and tach gauge bounces around 200-400 rpm.
Hook fuel pressure gauge to schreder valve below FPR got zero while turning over.
Changed fuel filter
Cleaned gunk from screen in FPR.
Still no fuel pressure while spinning over.
Ordered fuel pump.
Day 3:
Fuel pump arrived. Installed by the Sam Miller directions, went pretty smooth.
Put it all back together, still cranks but no start.
Checked Fuel pressure while cranking still got 0.
While spinning over I got plenty of white smoke.
There is plenty of fuel in the in the tanks, and the filter housing is full of fuel.
Now I need some help from the experts. Where do I turn next?
Thanks
David
Old 02-24-2011, 11:33 PM
JamesHajek's Avatar
JamesHajek
JamesHajek is offline
Check your HPOP Res...Oil should be within 1/2 inch of the top..
Old 02-25-2011, 01:24 AM
pjwoolw's Avatar
pjwoolw
pjwoolw is offline
Check to see if the harness / connection to the IPR is tight. Also the FPR / fuel bowl could be so gunked up its not allowing good fuel flow.
Old 02-25-2011, 08:27 AM
Action4478's Avatar
Action4478
Action4478 is offline
Did you get a CEL ?
Old 02-25-2011, 09:10 AM
Andy Sullivan's Avatar
Andy Sullivan
Andy Sullivan is offline
Any blown fuses? Had that happen when my fuel bowl heat broke going down a back road and lost power. Didn't know what was going on. I look at the fuses and it was a 30 amp that controls the glow plugs and alot of other things.
Old 02-25-2011, 07:08 PM
mercedes4oil
broke truck
Originally Posted by Action4478
Did you get a CEL ?
no sir, I do have a WTS light though.
Old 02-25-2011, 08:08 PM
Action4478's Avatar
Action4478
We need to verify that fuel is getting to the engine..
fuel level in the tanks ?
are the lines clear , broken pickups? .. is ti the same on both tanks ?
Old 02-25-2011, 09:10 PM
fordpride's Avatar
fordpride
fordpride is offline
Here'a WAG but it's worth looking at
See the arrow that say's FPR pull the 3/4" plug and see if the spring in there is broke
Old 02-25-2011, 09:23 PM
Action4478's Avatar
Action4478
The FPR is designed to remove air from the fuel ....That is why the screen being clean is important ....It controls the return to the tank ....Fuel pressure is what it is coming from the pump , the excess has to go back to the tank , along with what ever air is in the system . It has no other function ....
clogged up it can cause an uneven idle . Nothing more
Old 02-25-2011, 09:31 PM
Action4478's Avatar
Action4478
BTW ,
that is one dirty engine ...
Old 02-25-2011, 09:34 PM
fordpride's Avatar
fordpride
But if the spring is broke and not holding the psi then want it allow to much fuel to pass through and drop the fuel pressure. Please correct if i'm wrong
Old 02-25-2011, 09:35 PM
fordpride's Avatar
fordpride
BTW ,
That's not my engine hold on ain't that your's
Old 02-25-2011, 09:39 PM
Action4478's Avatar
Action4478
As long as it runs , I leave it alone
Old 02-25-2011, 09:42 PM
Action4478's Avatar
Action4478
Spent the day un bashing my frame from backing into a stump
Old 02-25-2011, 09:47 PM
fordpride's Avatar
fordpride
That suck's i remember when my truck got it's first scratch in 97 2 day's after igot it very sad day
Quick Reply: Crank no start F-350
