Ball joint tools - Ford Truck Enthusiasts Forums
Ball joint tools
Old 02-24-2011, 09:20 PM
nitro3421's Avatar
nitro3421 nitro3421 is offline
nitro3421 is gaining momentum as a positive member of FTE.
Ball joint tools
I also posted this question in the general Superduty section, but would like to get your guys' opinion as well...
I'm trying to make sure I have ALL the necessary tools to complete my upper/lower ball joint replacement. Here is everything I think I will need:
-3 Jaw pullers for hub & sway bars:
4 Piece Three-Jaw Puller Set
-Ball joint press kit (Do I need a special Ford adapter for this particular kit?):
Four Wheel Drive Ball Joint Service Kit
Possibly this OTC adapter (Do I absolutely need this? I'd rather not spend an additional $60):OTC Tools 6731 - OTC Ford Ball Joint Adapter Upgrade Kits - Overview - SummitRacing.com
-Pickle forks:
Grip-On Tools 5-Pc. Pickle Fork Kit, Model# 21318 | Ball Joint, Bearing + Gear Repair | Northern Tool + Equipment
Out of the ordinary sockets:
-1/2 drive 33mm socket
- 1/2 drive 21mm socket
- 1/2 drive 13/16" socket (for ball joint press)
- 1/2 drive 1-1/8" socket
-Home made knuckle seal tool:
Ford Super Duty Knuckle Seal Tool - AKA OTC 6695 | Superdutypsd.com
-Beefy impact wrench. It's time for me to upgrade, and was hoping to find a good used one on ebay. Any suggestions (make/model #)?
Anything else?
Old 02-24-2011, 09:45 PM
RNH Performance's Avatar
RNH Performance RNH Performance is offline
RNH Performance is starting off with a positive reputation.
you can rent the master front end suspension toolkit from advanced auto it has the short sleeve you can use for the ford.
replacr your hub o rings n check for vacuum lines for the 4 wheel drive. I also service the needle bearings....
Old 02-24-2011, 10:03 PM
White 99 White 99 is offline
White 99 is starting off with a positive reputation.
I am not sure what I was trying to seperate but of the size but my largest pickle fork was not wide enough when I did mine. I would look for the largest one I could find. Maybe someone else has a source for the correct one.
Old 02-25-2011, 04:46 AM
bcaughhorn's Avatar
bcaughhorn bcaughhorn is offline
bcaughhorn is gaining momentum as a positive member of FTE.
i havent done the ball joints on my f250 but on all the other ball joints ive done i didnt use the fork. i turned the wheel to one side and hit the spindle (rite at the ball joint) with a 3lbs hammer. if they have tension on they they usually come rite out
Old 02-25-2011, 06:44 AM
lhud lhud is offline
lhud is gaining momentum as a positive member of FTE.lhud is gaining momentum as a positive member of FTE.
NITRO,
Take one of your ball joints (lower is largest) and see which pickle fork fits that one.
I purchased some time back the IR impact: 1/2" drive with 1000 ft-lbs torque; Mdl IR2135QTIMAX.
It is light weight and a strong tool.
The Advance Auto kit (large one) will have all the required sleeves.
Not a bad job, but a little time consuming and some grunt work.
Very satisfying considering the money you will be saving.
Old 02-25-2011, 07:09 AM
Ziggy.'s Avatar
Ziggy. Ziggy. is offline
Ziggy. has a great reputation on FTE.Ziggy. has a great reputation on FTE.Ziggy. has a great reputation on FTE.Ziggy. has a great reputation on FTE.
It's not too bad of a job. I've got it down to 1 1/2 to do 1 side from start to finish. I don't use the ball joint press, I've got a round stock piece I hardened to use as a punch, and an old worn out 3/4 impact socket I had that I used to just punch the old joints out, all of the ones i've done so far came out pretty easy. The only thing I usually run into a problem with is getting the knuckle loose, I usually put a pickle fork on it to keep some tension downward on it, and beat it off with a 3lb sledge.
As the others mentioned It is a good time to service the needle bearing and vacuum hub.
You will also need a large set of snap ring pliers, The ones with the round tit on the end, not the flat end ones, for the snap ring on the axle shaft.
Old 02-28-2011, 08:21 PM
nitro3421's Avatar
Anyone want to sell me their homemade seal press? No where locally sells 1-1/4" threaded pipe, a flange & cap. I would gladly pay $20+ shipping...
Old 02-28-2011, 08:23 PM
nitro3421's Avatar
Quote:
Originally Posted by lhud View Post
NITRO,
Good call on the IR. I found a 244a used on ebay for $45, should be a great impact gun.
I'm just hoping I dont have to pay someone to do this. I only have a week timeframe to do this on a busy schedule between when I get the parts & when I'm leaving for a 3000 mile road trip...
Old 02-28-2011, 08:30 PM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to beholdtimmyboy76 is a splendid one to behold
Quote:
thats how i roll bud, but if your not try'n to "save" the ball joints, guess the pickle fork will work then.
Old 02-28-2011, 08:45 PM
onelionhunter onelionhunter is offline
onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.onelionhunter has a very good reputation on FTE.
Seal tool
Where are you located, maybe someone close by has the home made seal tool?
Old 02-28-2011, 08:48 PM
nitro3421's Avatar
Quote:
I'm in San Luis Obispo, CA. I'm also open to the idea of paying someone to do this job if anyone here wants to make a few bucks.
Old 02-28-2011, 09:40 PM
Bit far
Bit far for me, but I know we have alot of members in CA, hope someone is nearby that can assist in one way or another.
Anyone know the dimensions for the Hub seal installer for 05+ Yahiko 6.0L Power Stroke Diesel 17 08-16-2016 07:43 PM
BALL JOINTS - My turn - HELPFUL HINTS/LINKS 71-4R3SONS Excursion - King of SUVs 35 08-11-2014 10:25 AM
Replacing knuckle/axle seal on '2003 F250 Tact 1999 to 2016 Super Duty 8 12-17-2013 04:30 PM
Best ball joint tool to use on 2006 F150 4x4 shuttlevalve 2004 - 2008 F150 3 09-28-2011 02:42 PM
Ball Joint Press/Adapter? WY'01 1997-2006 Expedition & Navigator 3 06-10-2010 09:29 PM
Tags
2000, 6695, ball, balljoint, ebay, f250, homemade, joint, kit, lower, otc, powerstroke, press, rent, service, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
