390 stroker?
390 stroker?
Probably been asked a million times before, but got to find out...
Trying to determine if I have the 360 or 390:
At a bore diameter of 4.05 the only difference between the 360 and 390 is the stroke. 360 = 3.5" stroke, 390 = 3.78" stroke.
So I decide to check my stroke to find out if i bought a 360 or 390. I pull the plug, drop a rod down, slowly turn the engine around till i get the tdc and bdc and came up with
3.98" stroke.
Thats the crank used in the 410 and 428 if i remember correctly. Is it even possible to drop that crank into the 390?
3.98" stroke.
I bought it from thew original owner. His memory has slipped alot, but he had the actual receipts from the rebuild in '94. Must have bought the crank someplace else because it didn't show up on the receipt. A set of .020 rings and pistons did tho.
DEEPROOTS:might want to make sure you have the hatchet by the balancer
uh-hatchet? an external lobe or something?
Krewat:
Did you actually check the bore, or did you check the stroke with the heads still on it?
I did a heads on measurement with a dowel from bottom to TDC, and when the number came back bigger I checked it again. same-same.
DeepRoots:
No clue what the hatchet is. External crank balance?
DeepRoots:
The 410 uses the 428s 3.98" crank. So they are both externally balanced. The FT cranks are externally balanced, forged steel and have a larger diameter snout. They can be made to work by having this snout turned down to FE size. You would also have to have the correct flywheel, harmonic balancer/pulley, and timing cover. They do not however come in the 3.98" size.
crap, I couldn't find a photo.
It's an external balancer on the front of the engine. It's visible with no disassembly. If it doesn't have it, either:
1. It isn't a 410
2. It isn't balanced properly, and will not run well
3. The crank was internally balanced (VERY unlikely)
1. It isn't a 410
