390 stroker? - Page 2 - Ford Truck Enthusiasts Forums
390 stroker?
Old 03-01-2011, 06:59 PM
Sleepy445FE's Avatar
Sleepy445FE Sleepy445FE is offline
Sleepy445FE is gaining momentum as a positive member of FTE.Sleepy445FE is gaining momentum as a positive member of FTE.
Ok, take the cover off and take a look at your flywheel. It should look like this428 Cobra Jet Flywheel Identification
Old 03-05-2011, 07:16 PM
glosol's Avatar
glosol glosol is offline
glosol is starting off with a positive reputation.
OK, working on that next...
Old 03-06-2011, 11:31 AM
dinosaurfan dinosaurfan is offline
dinosaurfan is gaining momentum as a positive member of FTE.
Smile never mind the flywheel, ......
Glo, never mind the flywheel, it doesn't mean anything, and doesn't matter. ALL of the FE flywheels fit, and all of them can be rebalanced on a spin machine in about 10 minutes to work with the 410-428 cranks. If you have the 4 inch stroke ( 3.98 ) then someone swapped in another crank before you got the truck. Bonus for you. The 410 and 428s have been out there since '66, and wheredo you think their cranks end up if the block breaks or something ? lucky guys put them into 390s and 360s. If the engine runs smooth, someone rebalanced the flywheel or used a 410/428 'wheel. Most likely the original 390 wheel was rebalanced, because most of the 410s and 428s came in front of auto trannies. DF
Old 03-06-2011, 11:58 AM
Good point. Very probable it was a rebalanced 390 flywheel. If it's not vibrating then its fine. Enjoy it.
Old 03-07-2011, 11:11 AM
glosol's Avatar
That is a good point. I do have great power, enough to smoke the 37" tires, but that isnt saying much.
Thanks!
410 out of 360 Nick-1973-ford 1973 - 1979 F-100 & Larger F-Series Trucks 11 07-14-2016 08:30 AM
390 crank ID elkarcher1716 1973 - 1979 F-100 & Larger F-Series Trucks 12 04-27-2016 08:47 PM
Parts ID - easy stuff please help toddspeed FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 03-21-2013 11:35 PM
Serious 360 head scratching nobearsyet FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 41 02-19-2012 08:43 AM
390 or 360 nobull4x4 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 4 12-07-2004 03:48 PM
Tags
360, 390, 410, 445, balanced, engines, fe, ford, forged, internally, performance, steel, stroke, stroker, turbo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
