so i have cracked the lines and have been cranking it for the past half an hour i have sprayed starter fluid and it wants to start but there is no fuel pressure yet. Do all the lines need to be open? and if there is no presure what else can i look for?
fill the fuel filter up and put it back on and crank till you see fuel coming out of your injector lines. Then fill it back up and it should start and run long enough off of the fuel filter to reprime the system.
just turn on your electric fuel pump and give it a couple mins,she'll fire right up like nothing happened and keep your starter happy.
if you haven't converted (or plumbed one in for backup) yet,well.might i suggest a search.
