2011 super duty -weird!
ok, so im on the ford "build your truck" part of there site.. two trucks exactly the same,one f250 one f350 base price is $1400 apart, but if you look at the line up on the main page it says 50's and 350's are only $715 apart. ALSO...it says the f250 (6.7 s/c ) has a 2690lb payload and will tow 13,500lbs...the f350 says 2480 lbs payload and will tow 12900 lbs...odd
Payload is GVWR less the weight of the truck. Towing capacity is GCVWR less the weight of the truck. Depending on the cab/bed configuration combination, the weight of the truck will alter what's left of the GVWR (arbitrary rating) and GCVWR (based on gearing/engine), leading to differing payload and towing capacities.
All you need to know is the truck are 98% identical mechanically, FGAWRs vary by package selection, GVWR is an arbitrary number, and GCVWR isn't a real rating anywhere but in the Ford manuals.
So really, there's no practical difference between the two unless you're expecting to run into a legal problem coming from exceeding the GVWR.
Unless Ford has departed from the last 12 years of SD history, the frames are still identical across the 250/350 power unit lineup.
Did they change something in 2011?? Don't they both have solid front axles? And I'm pretty sure you can get the same springs in the 250. There's a taller rear block in the 350 but I think that's the only difference in the suspension.
Brakes:
From 2011 specs: Vacuum (F-250/F-350 SRW gas engines) / hydro-boost (F-350 SRW diesel engine, F-350 DRW/ F-450)
From 2010 specs: Vacuum (F-250/F-350 single-rear-wheel gas engines) / hydro-boost (F-350 single-rear-wheel diesel engine, F-350 dual-rear-wheel F-450), ABS
From 2007 specs: Vacuum (F-250/F-350 single-rear-wheel gas engines) / hydro-boost (F-250/F-350 single-rear-wheel diesel engine, F-350 dual-rear-wheel), ABS
I'll be got-damed, I never noticed that. I don't know if it's a typo or if Ford really changed it, but I don't know why Ford would go through the hassle of having two sets of brake components bolted on to otherwise identical 6.7L diesel engine bay configurations.
Solid axle is a 2wd versus 4wd issue. Spring capacity for the front axle is based on package selection (Snow plow, front heavy service). Rear springs are physically identical, but RGAWR varies with the GVWR, but it doesn't matter, it's just a number on a sticker. (EDIT: I checked some VIN tags I have pics of, all the 250s I've got recorded have a RGAWR of 6100#, so I'm guessing it's a de-rating based on the de-rated GVWR the 250 already gets)...
Sorry...that is what the Ford guy that sits behind the desk and builds vehicles on the computer all day long told me at the dealer. I had asked him why the 350 sits about 4 inches taller than the 250 with the same size wheels and tires. They had two 350s and half a dozed 250s and the 350s were noticably taller. I was curious why and that's what he said.
The rest of that rant comes from a severe case of Napoleon's complex I've got going on, because I won't admit that my F250 is any less of a truck than an F350, just because the stupid plastic badge on the side of the truck tells me so.
