Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Steering and Suspension Guides
- How To Install Airbag Suspension
Step by step instructions for do-it-yourself repairs
HOW DO I REPLACE A REAR SUSPENSION AIRBAG?
Hello everyone i need your help i did the soap test on the back suspension and the right air bag leaks considerably. needless to say i need information on where to buy a inexpensive set of airbags and how do they get replaced any pdf files available? also i need new bushing for the compressor all three are broke and it sounds like a air hammer. please let me know if you have any suggestions on making this easy to replace. thanks for you help.
You didn't specify a year. My wife's 2001 expy had bad airbags, I just decided to convert to coil and shocks using a kit from Rockauto.com. The air shocks are easy to remove, first turn off your air suspension switch, usually located right under the glove box by the kick panel. Raise the truck, once you get to the bad air bag you will have to remove a silver clip on the selonoid connector, turn it counter clockwise to release the air and remove the connector, then remove the clip on the top of the airbag, you can access it with needle nose pliers if you look in between the frame and the body on top of the air bag, you willl see it. Just pull it straight towards you. then pry the bottom of the air bag up and it will release from the clip in the axle. Hope this helps.
Try Lincoln Air Suspension Parts from the REAL Air Suspension Experts for your parts. They are highly recommended by others here. As far as instructions, I found this video for a conversion. It shows the air bag removal. Putting a new bag in is just the reverse. I am actually waiting for the Monroe conversion kit in the mail and I'll be done with my air suspension problems.
YouTube - Ford Expedition Air Suspension Conversion Kit Install - 97-
brc777
1983 - 2012 Ranger & B-Series
01-06-2017 01:34 AM
Bmartin_emt85
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
09-20-2015 04:30 PM
SgtHch
10-15-2013 05:29 PM
BVA
1997-2006 Expedition & Navigator
15
02-25-2012 10:28 PM
