96 Ranger clutch slave cylinder issue - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 02-24-2011, 02:59 PM
fordparts76 fordparts76 is offline
fordparts76 is starting off with a positive reputation.
Exclamation 96 Ranger clutch slave cylinder issue
Hey all.
I just recently replaced a leaking slave cylinder in my 96 Ranger. Not my first slave replacement by any means, but having an intermittant issue.
After everything was reassembled and bled, I drove the truck for about a week with no problems. Now, after driving for about 40 miles, the clutch pressure fades until the clutch stops disengaging. I'll let it sit for about an hour or two and it has great pressure again. Only once have I had to top off the reservoir. No visible leaks from the master, reservoir or line. There was brake fluid dripping out from the bell housing the first time it happend, but that was it, none since then. I have another new slave in stock, but I don't want to rip this thing apart again if I don't have to.
This is stumping me and the techs I work with!!
Old 02-25-2011, 06:08 AM
wp120470's Avatar
wp120470 wp120470 is offline
wp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to beholdwp120470 is a splendid one to behold
I know you looked, but is there any fluid coming from the back of the master in the floor?It could have a bypass problem.
Old 02-25-2011, 08:59 AM
Nope. No leaks inside. I may just replace the master and line. The truck has close to 200k miles.
Old 02-25-2011, 10:04 AM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Quote:
make sure you bleed it correctly
YouTube - Ford Ranger & Mazda B-Series Pickup Clutch Hydraulic Release System Bleeding Procedures
YouTube - Removal and Servicing of Clutch Master Cylinder to Slave Cylinder Connections
Old 02-25-2011, 10:40 PM
danielwd danielwd is offline
danielwd is starting off with a positive reputation.
Hey all.
That leaking fluid from the bell housing is what happened to me after replacing clutch, slave, and pilot. The slave then worked very strangely from the at point on. So I disassembled the whole dang thing and took it back to autozone. They played with it and assumed I did not bleed good enough and as a result I damaged it. They were nice enough to give me another.
On the second try, I bled the freakin' crap out of that thing. I bled and bled it...and it has worked great since.
Clutch line popping off slave cylinder templars Ranger & B-Series 3 07-07-2015 08:35 AM
Bad Slave Cylinder??? uh60 1987 - 1996 F150 & Larger F-Series Trucks 9 11-10-2013 07:45 AM
So what's the dumbest thing carrcreekcaller 1999 to 2016 Super Duty 33 10-11-2013 07:45 AM
New clutch slave cylinder seal leaking jkschneider 1987 - 1996 F150 & Larger F-Series Trucks 21 01-25-2013 12:42 AM
94 Ranger Clutch Problems fixitup Ranger & B-Series 8 01-26-2006 08:07 PM
Tags
1996, 96, cluch, clutch, cyl, cylinder, drawing, ford, leaky, problems, ranger, reservoir, slave, symptoms, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
